Change in weight and feel. When did it happen?
Been liked: 46 times
Re: Change in weight and feel. When did it happen?
Skeezix wrote:
How big is your gas tank?
Gasoline is 6.183 pounds per gallon.
US or UK (imperial) gallon? There is a difference.
But nowhere near 50kg difference just on fuel.
Ah - but that raise two problems...
1.  How much does a pound weigh in new money?
2.  Whose gallon - yours or ours?
What's to formula US to proper.  Can't be much more than a gallon difference in a tank.
Been liked: 474 times
One US gallon is approximately 0.832674 Imperial (UK) gallons,
or
one Imperial (UK) gallon is approximately 1.2 US gallons.
tony23
Post by tony23 »
Petrol weighs about .74 kg per litre so 25 lit tank approx 19 kg. Specific gravity is less than water :) .
That explains why bikes exported to the US do 20% less to the gallon.
DaveCly
Has liked: 70 times
Been liked: 51 times
Post by DaveCly »
Ohhh my head hurts  :alas:
Good job a lb is still a lb over there or we would be here all day.
leonjennings
Post by leonjennings »
so 6 penguins fill 3 tanks in 6 minutes, how may minutes does it take 3 penguins to fill they same amount?
2012 SE
12 US Minutes  8)
guest3954
Post by guest3954 »
RTman10 wrote: Hold up guys, the best RT's ever built are the 2010-13 models.
Building sandbag fire wall as i type....... :kacsint2:
You are obviously in denial mode and you know full well they were stop gap models with a borrowed engine. All down to the extended development time of the LC .
And the borrowed tuned down engine fitted to the TC is the best engine they ever built.
One of the reasons they threw it away and started again.  When they run out of bits they will probably stop using it in the Nine T.
Sprintgull
Post by Sprintgull »
Be careful. Put US gallons into a UK tank and they don't fit properly.  Next post will be to ask about a mysterious rattling noise.
Sprintgull wrote: Be careful. Put US gallons into a UK tank and they don't fit properly.  Next post will be to ask about a mysterious rattling noise.
That would be my fillings when riding our 2010 RTP with the best engine they ever built  8)  Got to say though, don't feel as much vibration though the bars as my LC
