Here you go.LC cool wrote: Littlebriar can you post photos of your lights on you crash bars.
My Friday project.
- Littlebriar
- Been liked: 1 time
Re: My Friday project.
Steve
My apologies as I think I may have caused confusion. The term auxiliary its misleading. I should have said the positive battery terminal that is visible from the side and is covered by a red plastic cap. This is shown in the owners manual.
UKDucatiman
Clearwater lamps
I've got a set of their Darla lamps to fit. They are quite small so hopefully won't look too out of place. Unlike the later bikes there is no plug-in soluction for my 2006 RT. In this case I need to break into the loom. The instruction are comprehensive so hopefully it wont be too difficult, I just need to allow plenty of time to get the job done.
- timminator
- Been liked: 2 times
Re: Clearwater lamps
If you can find them, I highly recommend posi-tap connectors. They will allow you to tap into the existing wire harness without cutting and can be removed later, leaving only a small pinhole in the insulation. I used them to connect an autocomm to the factory radio (see photo).UKDucatiman wrote: I've got a set of their Darla lamps to fit. They are quite small so hopefully won't look too out of place. Unlike the later bikes there is no plug-in soluction for my 2006 RT. In this case I need to break into the loom. The instruction are comprehensive so hopefully it wont be too difficult, I just need to allow plenty of time to get the job done.
BMW MOA #210438
UKDucatiman
timminator wrote: If you can find them, I highly recommend posi-tap connectors. They will allow you to tap into the existing wire harness without cutting and can be removed later, leaving only a small pinhole in the insulation. I used them to connect an autocomm to the factory radio (see photo).
Good call, I need to check but I'm sure the Clearwater install kit comes with posi-tap connectors. If not I will certainly try and get some.
