Is anyone else experiencing the following:
-> audio via the RT using an USB Stick
Audio sounds fine over speakers and Bluetooth.
-> Insert Nav V into cradle
Audio still sounds fine over the speakers.
Over bluetooth, using a Sena 20S, i get, even on the unconnected AUX channel, a high/hissing noise. Like in the old days, when you had your amp wired badly and the fridge went on....
Is this considered "state of the art"? Should i disconnect the Nav V Audio?
Frank
BT audio has a hissing background as soon as NAV V is in the cradle...
Re: BT audio has a hissing background as soon as NAV V is in the cradle...
It may not be the answer you're looking for Frank but there are only two solutions - get a BMW helmet, with BMW bluetooth or fit an Autocom. The BMW stealers will tell you that no other bluetooth system will work properly with an audio-equipped RT and in my experience they're right. The only saving grace of being forced down the BMW helmet +BT route (at £750, if you're lucky) is that the helmets are fab and the BT faultless.
The stealer will also probably tell you that Autocom won't work - my dealer claimed they'd had owners describe it as a "virus". My own experience is that autocom is easily installed and works perfectly.
Oh, for an honest dealer...
