Hi guys,
I've searched all over and can't find a definitive answer on where to plug a CANsmart (or EZcan) on my 2024 R1250RT. I have removed the cowling and found the RDC plug that the instructions say to use if you do NOT have TPMS. I also see the DWA module under a plate (which I have not removed), but I don't see an actual RDC module in the rear of the bike. I found excellent illustrations of the RDC and DWA modules at the Chigee site, so I know what I'm looking for. I also found a video of the installation on an older RT, and he said that the RDC module was moved to newer RTs, but he had no idea where it is. I've found nothing posted in the past 3+/- years showing how to install on an RT. If I can just plug into the RDC plug, that would make it really easy, but the instructions specifically say that the CANsmart/EZcan should not be plugged in there if you have TPMS.
Any help would be appreciated.
Installing CANsmart/EZcan on 2024 R1250RT
RockingCPA
- Bike Model and Year: R1250RT 2024
- Been liked: 1 time
Usernamemike
- Has liked: 12 times
- Been liked: 3 times
Re: Installing CANsmart/EZcan on 2024 R1250RT
I have a 2024 model as well and have installed the Denali CANsmart. Have you managed to install yours yet? If not, I can try and help.
- exportman
- Has liked: 16 times
- Been liked: 75 times
Hi
There is a blanked plug under the top box carrier. Difficult to find without removing the carrier but it is possible if you plug it into the wrong place you get all sorts of errors.
- Been liked: 560 times
He posted then never came backUsernamemike wrote: Wed Sep 17, 2025 8:27 am I have a 2024 model as well and have installed the Denali CANsmart. Have you managed to install yours yet? If not, I can try and help.
Usernamemike
Ah. I noticed his post was in May and apparently no one had responded at least until my response. Since the post was quite a while ago, I didn't think I'd hear anything. Thank you for confirming.
- Stu
- Administrator
- Has liked: 696 times
- Been liked: 729 times
- Stu
- Administrator
