This includes the Yoke, a set of GS bars.
These sit approximately 75mm higher than the standard bars and are 100mm wider (830mm vs 730mm).
You can remove up to 30mm from each end of the GS bars if you prefer something narrower.
Evotech bar end weights now sold so you will need bar weights.
£160 posted.
For Sale - R1250RT Tubular Bar Conversion
- tubetop.jpeg (122.5 KiB) Viewed 1705 times
- IMG_0866.jpeg (171.54 KiB) Viewed 1705 times
- IMG_0865.jpeg (204.36 KiB) Viewed 1705 times
- IMG_0864.jpeg (162.46 KiB) Viewed 1705 times
- IMG_0863.jpeg (180.73 KiB) Viewed 1705 times
- IMG_0418.jpeg (289.45 KiB) Viewed 1705 times
- front.jpeg (218.45 KiB) Viewed 1705 times
- 2C169A19-5BD8-4A70-9087-3E5CE382CA67.jpg (127.38 KiB) Viewed 1705 times
