Anti seize advise please.
What can I put down a barrel to stop it and the piston becoming stuck over winter.Is there a specific oil that does the job or just a matter of any old oil,thanks.
Re: Anti seize advise please.
Any decent motor oil is what I would use
Although what makes you think it will become stuck?
My 1980 Yamaha XJ650 Owner's Manual recommends the following. Pour about 15ml of the correct viscosity engine oil in each cylinder.
The 2012 BMW R1200RT Rider's Manual doesn't mention putting oil in the cylinders.
I don't bother on either bike. The RT is usually stood for 5 months, the XJ650 can be less, neither has seized up.
Thank you for the replys.I should have been clearer, this is for my Lambretta. I'll put some 2 stroke oil down it then.
Stu wrote: Mon Sep 29, 2025 5:15 pm Any decent motor oil is what I would use
It's a brand new piston/barrel.Never been run and the money I've spent is eye-watering.Me garage isn't the warmest place so I want to pre empt any issues over winter. Here's another 1 for you.The scooter has a SS long range petrol tank that's never had fuel in it,thoughts on preventing any internal corrosion,I don't really want it sat there with a full tank of petrol.
if the tank is a decent quality of stainless steel then it should be OK
But you could easily coat it again with 2 stroke oil for peace of mind then flush it out next year
Stu wrote: Mon Sep 29, 2025 6:29 pm if the tank is a decent quality of stainless steel then it should be OK
I had thought of that but its a bugger of a tight fit getting it in and out :mrgreen:
Both my motorcycles are stored with fuel tanks brimmed with petrol. One is steel, the other is plastic.
On the XJ650, I used to drain it and add a cup full of engine oil, shake the tank to thoroughly coat the internal surfaces.
burridge01 wrote: Mon Sep 29, 2025 6:58 pm I had thought of that but its a bugger of a tight fit getting it in and out :mrgreen:
I dont think you are supposed to stick that in there :shock: :lol:
Been liked: 258 times
The engine fitters in the RAF used to say 'A full tank is a safe tank' It's the vapour that ignites so the less room the less vapour.
