Clutch drag-clutch lever pulled in
coarsegoldkid
- Bike Model and Year: R1200RT 2005
This is driving me nuts. Bike is a '05 R1200RT. All help is appreciated. Bike at idle. With the clutch lever pulled in and I drop trans into 1st gear the bike wants to move forward, and when the front brake is pulled the engine will stall. Why isn't the clutch disengaging with the engine. Thanks
- Been liked: 506 times
Re: Clutch drag-clutch lever pulled in
In the Haynes manual Fault Finding section, under Clutch problems, it suggests the following.
Clutch not disengaging completely (drag).
Clutch release mechanism faulty. This will cause clutch drag, which in turn will cause the machine to creep.
Clutch pressure plate warped or damaged.
Clutch diagram spring broken or weak.
coarsegoldkid
Thanks. I was afraid of the plate being damaged some how. Now to discover how to split the engine from the transmission.
