Starting engine in neutral gear
- Stu
- Administrator
- Has liked: 696 times
- Been liked: 729 times
Re: Starting engine in neutral gear
With it in gear and the side stand up and the clutch pulled in it should start.
If not then you need a new clutch switch
MarkW
- Bike Model and Year: R1200RT 2012
- Has liked: 1 time
- Been liked: 10 times
Have you by chance got grip puppies or similar fitted? You know, the foam tube thingies that add a little comfort and are supposed to reduce vibration fatigue. I had your problem and it turned out the addition of the foam grips stopped the clutch lever being pulled in far enough to engage the bybass switch. I removed them and the problem was solved.
Just a thought.
Just a thought.
Arends
- Bike Model and Year: BMW R1200RT 2015
- Has liked: 59 times
- Been liked: 18 times
I had the sane issue the last year. Cleaning and waterproofing the clutch switch resolved the issue.
This autumn is really wet in Ireland, and although my bike is under a cover and I try to ride it on regular basis, the issue reappeared. I'll be getting a new switch at my next service.
I am here to learn.
