Is my swing arm bent?
Just removed the driveshaft from my 07 r1200rtp. Should it just pull out once disconnected at the front? Mine was binding against the rim of the rear hole. I had to put a screwdriver through the joint and tap it out to get it free where the shaft gets wider.
- Has liked: 1695 times
- Been liked: 549 times
Re: Is my swing arm bent?
No, they can be a bugger to get out
