05 r1200rt front brakes need advice on parts
JustmeandtheRT
Germany
Post by JustmeandtheRT »
So I’ve taken them apart to fix and paint my wheel and I mixed up fasteners got a vibration so now I’m on the market for rotors but I’m lost in translation full floating semi floating are the wave washer washer bolt and spacer cylinders reuse able with aftermarket brakes do I even need them some just show bolts and list hardware included
Re: 05 r1200rt front brakes need advice on parts
It is not recommended to reuse the bolts, but saying that ive always reused them with Loctite. Can't see how you can mix them up. They are all the same size. Unless you had vibration before disassembling, there should be none now unless you've fitted them wrong
