Plastic key Function
gavanhe
Post by gavanhe »
Having recently purchased a second hand r1200rt, I was supplied with a plastic key. Does any body know its function. I am unable to locate a reference to it in the manual.
Cheers
Gerry
Gerry
Re: Plastic key Function
Its just an emergency key.  It has a chip in it so will start the bike.
wayneosdias
Post by wayneosdias »
gavanhe wrote: Having recently purchased a second hand r1200rt, I was supplied with a plastic key. Does any body know its function. I am unable to locate a reference to it in the manual.
Cheers
Gerry
To add to what RTman said, it doesnt have the full range of the FOB key. It must be placed, or wedged if you will between the top of the cluster and fairing in order to work. This is per the dealer, I personally have not tried it on my bike.
wayneosdias wrote: To add to what RTman said, it doesnt have the full range of the FOB key. It must be placed, or wedged if you will between the top of the cluster and fairing in order to work. This is per the dealer, I personally have not tried it on my bike.
I'm confused. Its just a key. It fits in all the locks. Not very strong though and you could snap it off undoing the steering lock if its stiff. If you have a keyless system it can be used for starting by holding it very close to the fuel filler cap and pressing the keyless button.
Been liked: 474 times
wayneosdias wrote:It doesn't have the full range of the FOB key. It must be placed, or wedged if you will between the top of the cluster and fairing in order to work.
Looking at the Rider's Manual, (page 52), there is a picture showing the emergency key centred into the gap above instrument panel.
This is for Bikes which have "Ignition with Keyless Ride".
gavanhe wrote:Having recently purchased a second hand r1200rt.
What year is the Bike, is it a Euro or USA Model & does it have Keyless Ignition.
gavanhe
Post by gavanhe »
It's a 2014 model in Australia, not keyless, just central locking !!
Gerry
gavanhe wrote: It's a 2014 model in Australia, not keyless, just central locking !!
In that case it's just an extra ignition key.
