Navigator Motorcycle Information Screen
monty
Post by monty »
Hi - I've seen a video where the Navigator V was demo'd on a GS and you could see lots of data about the bike on the screen which I believe was customisable
Can you get the same sort of information from the new RT ?
I did see something on the web that suggested this was only available on the GS and Adventure
Thanks
Ian
Re: Navigator Motorcycle Information Screen
That's correct.  It's only available when mounted on a GS.  Impossible on an RT
monty
Post by monty »
That's a bummer - I was quite impressed with that - what makes the GS different in terms of things like engine temp, tyre pressure etc ?
Thanks for responding again :)
Monty
I suspect it's the nonability of the dash to display it all.  The RT already displayed some of the items and some of it is recorded in the Nav V. Who really wants to know how many times you have changed gear anyway.
monty
Post by monty »
Thanks RTMan10
slparry
Has liked: 12 times
Been liked: 35 times
Post by slparry »
RTman10 wrote: That's correct. It's only available when mounted on a GS. Impossible on an RT
also available when mounted on an R1200R or an R1200RS too, only  the RT doesn't have it :(
johnesherman
Post by johnesherman »
Let's see if I understand the question: BMW Garmin Navigator V mounting on R1200RT bike?
I have a 2016 R1200RT, installed a BMW Garmin Navigator V GPS into the Bike's prewired socket for GPS unit mounting; as a result, the Navigator V, without push-button base used, mounts directly to the bike's GPS socket and operates all right.
The Navigator V works with the 'wonder wheel' but I don't believe it has all the data readout information presented that a K Exclusive bike has access and presents on GPS Navigator V display use? I don't have a K bike so I really don't know.
The prewired R1200RT GPS socket will support a Garmin LM660 GPS use, but the Garmin LM660 internal battery will not charge from bike's power source; as a result, no 'wonder wheel' GPS control and LM660 GPS will only stay powered and usable depending on LM660 GPS internal battery charge remaining.
Side note: According to Garmin Customer support for motorcycle products and BMW Navigator GPS products: The Navigator
V GPS may be used in the LM660 auto or bike mount without damage to unit. I have not tested this to see if the Navigator V battery charges all right while in these other mounts?
John Sherman R1200RT Tacoma WA USA
Been liked: 46 times
johnesherman wrote: Let's see if I understand the question: BMW Garmin Navigator V mounting on R1200RT bike?
I have, used to have a 660 before the Nav V, 660 charged ok in Nav V mount. Now i have a Nav V, it charged ok on my Harley with a 660 mount, behaved the same as the 660 did, which I gave to my son.
MacJ
Post by MacJ »
My Zumo 660 works fine on the RT GPS mount, including charging,  although I don't have the functions of the Nav via the wheel..
Oddly though the GPS menu is available on the bike dash when the 660 is installed so it obviously recognises that there is a GPS there.
guest3074
Post by guest3074 »
johnesherman wrote: , but the Garmin LM660 internal battery will not charge from bike's power source; as a result, no 'wonder wheel' GPS control and LM660 GPS will only stay powered and usable depending on LM660 GPS internal battery charge remaining.
The Garmin 660LM will charge in the RT with GPS prepared bike, just you will not have audio integration to the bike or wonder wheel access to the sat nav.
The functions of the Nav V on the K1600 and the LC is identical as the dash is to all intense and purpose the same.
All,other types of Garmin units might work to some degree but not fully.
For me that is why I buy a GPS unit that is designed to work with the bike and it's mount.
