Deep clean
UKDucatiman
Deep clean
I finally got round to giving the RT a good clean after her trip to Italy. Tried out the dirt devil cleaning foam which really did the trick. Any suggestion on removing some scuffs from the seat? Tired legs causing me to clip it with my boot a couple of times, cosmetic only.
Re: Deep clean
Doc Baileys Black is the stuff you want. Waterproofs and restores leather. Use it on my saddle and leathers
UKDucatiman
Re: Deep clean
Great, will give that a tryCasbar wrote: Doc Baileys Black is the stuff you want. Waterproofs and restores leather. Use it on my saddle and leathers
Re: Deep clean
Isn't the stock seat vinyl?
If so a good going over with mild detergent should do the trick
Products like armour all should not be used as they make seat slippery
I also cover bar end switches before washing, as they can be somewhat water sensitive
Re: Deep clean
UKDucatiman wrote: I finally got round to giving the RT a good clean after her trip to Italy. Tried out the dirt devil cleaning foam which really did the trick.
Looks like to sprayed it with a fire extinguisher!!
:alas: :alas:
UKDucatiman
Re: Deep clean
That would have been a classic 'should have gone to spec savers' moment ;Drichardbd wrote: Looks like to sprayed it with a fire extinguisher!!
:alas: :alas:
Steve F
- Has liked: 1 time
Re: Deep clean
Yes, the stock seat is best kraut vinyl!T6pilot wrote: Isn't the stock seat vinyl?
Re: Deep clean
Missed that bit, I haven't used it on my RT as I have only had it a couple of months, but used to use it on my Harley which had a leather seat
Re: Deep clean
Dirt Devil or Demon cleaning foam ?
Looks good but can't find it, could you post a piccie of the stuff please?
UKDucatiman
Re: Deep clean
Sorry, actual name of product is 'CarPlan Demon Snow Foam'Cleverbee wrote: Dirt Devil or Demon cleaning foam ?
Re: Deep clean
Some BMW alloy parts don't take kindly to aggressive cleaning products. I would make sure that you give it a thougher rince and then do it again. I have seen many bikes damaged by the likes of MuckOff especially round the foot peg hangers and drive shaft.
As it seems to be designed mainly for cars such items might not have been considered .
UKDucatiman
Re: Deep clean
Yes, don't leave the stuff on for too long and give it a good couple of rinses, especially for the post 06 bikes, with those corrosion issues
