Not yet an owner
Not yet an owner
So, I have only had 2 motorcycles in my 4 years of riding, both Yamaha cruisers. I am now VERY interested in the r1200rt, mainly because i am a 5'4" female with a 28" inseam and I believe the lower seat on this bike, coupled with it's lighter weight, will work for me. I am on the lookout for a used one in my area and hope to be able to find one soon. In the meantime i thought i would read and learn all I can on this forum.
Re: Not yet an owner
I believe in years past BMW offered both a low seat and low suspension option, today's bikes only a low seat, congrats on the soon to be new ride
I'm sorry to say you might struggle. The LC is a minimum of 760mm which is OK for a 29in inside leg, just. Pre 2014 bikes were available with lowered suspension and they were 750mm and being a bit lighter is your best bet. Not many of them around though.They came out of the factory with a non adjustsble low seat but not heated.
- blokeonthemove
There is a low suspension version of the R1200 GS (A), which according to many on the other forum, is ok. Worth a try to see if it suits. The previous version of the RT with the oil/air cooled engine was a very nice bike and lacks that extra cooling complication of water and it's pump.
Thank you all for your input. We have a 2011 RT for sale in my area and I hope to go view it soon. Fingers crossed!
Vstark wrote: Thank you all for your input. We have a 2011 RT for sale in my area and I hope to go view it soon. Fingers crossed!
Take a step ladder...
falconmick
Welcome to the forum
I have a 2011 R1200RT with the lower seat option, am 28'' inside leg and have no probs. Also you might be interested to know that Altberg boot manufacturer in Richmond, N Yorks will make top quality boots to order at sensible prices and can put a thicker sole on, every little helps. good luck.
And, the twin cam engine'd bikes are very capable machines, proven, and affordable. just my tuppence worth :-*
Thanks for the info about the boots, I will look into that. This group is cool!
Vstark wrote: Thanks for the info about the boots, I will look into that. This group is cool!
Daytona also make a boot that looks completely "normal" from the outside but that has a raised insole to add a bit of height. It's called the Ladystar GTX.
Vstark wrote: Checking on this! Thanks much.
I still like the stepladder idea the best...
mannylasker
I have a 29" inseam with the low seat on a 2015. I can "almost" flatfoot but not quite. I'm thinking 28" will be toes only. Good luck in any case.
Together with a pair of those 1970s high healed glitter boots.
