I started noticing an intermittent "shudder" when taking off a few months ago. Only happened during clutch release into first gear and would stop once clutch was fully released and bike moving. It was pretty noticeable, when it would do it, but was intermittent (maybe once a week and I ride daily). Recently it did seem to be getting worse (and I kept telling myself "need to check on that" - doh!).
Then yesterday, "it" went out (question is - what is "it")?: I was driving down the freeway for a Sunday ride, and the bike starts shuddering. I'm in sixth gear doing ~80mph. I pull in clutch - no shudder. Made my way across four lanes of freeway onto the off-ramp. Drove about 100 yards to see if I could "limp home" - no way. It shudders in all gears, and only stops when I pull in the clutch and coast. I pulled into a parking lot and used my BMW MOA roadside assistance for the first time and got towed home.
I had the FD fail two years ago so I know what that feels like. I checked that first off, and FD is almost certainly NOT the issue. Note no symptom coasting w/ clutch in.
Anyone have ideas on what failed, based on the symptoms? There is a drive shaft with a pair of universal joints (CV config) as I can tell from the parts fiche. I've had U-joints go out on caged vehicles that had similar symptom. My wishful thinking is that it is something like that and not the transmission proper. I haven't dug into it yet and am inclined to take it to the dealer ($$) due to no-time. But if anyone has ideas on what it might be, and if that is not to invasive, I'd take a look at doing it myself. I can do almost any repair, but it will be a matter of time required. If I can fix it in a weekend, I'll do it myself. Otherwise, I need the bike running as it is my main transportation.
2005 R1200RT
89K miles
