Heated Grips
guest3954
Heated Grips
Post by guest3954 »
Whilst riding early hours, for several high speed motorway hours, on a very cold morning - full beam on, front seat on, pillion had seat on max setting, grips on max - I noticed left hand grip was not quite as hot as the right. When I turned riders seat off it seemed to balance out. Has anyone noticed this? Or could account for it? ::)
Been liked: 46 times
Re: Heated Grips
No, what bike? If the can bus was limiting power, then it normally switches an item off.
guest3954
Re: Heated Grips
Post by guest3954 »
R1200RT TC 2010
Re: Heated Grips
Mike wrote: R1200RT TC 2010
I'm sure someone more knowledgable will be along shortly, I have an LC but do ride a 2010 RTP, but that doesn't have heated seats
Re: Heated Grips
Never heard that one before.  Could it be your brain and not the bike.  If it was low power you would expect the canbus to switch off both.  Try with different heat settings on the seat . But the right one normally does feel a bit cooler as you move your hand more with the twist grip which also has an effect on it.
guest3954
Re: Heated Grips
Post by guest3954 »
Will try that. It might have been me. Long ferry crossing - then towards the end of a six hour push for home.
Re: Heated Grips
Mike wrote:R1200RT TC 2010
Does the bike have cruise control.
guest3954
Re: Heated Grips
Post by guest3954 »
Yep. Cruise, ESA it's SE model.
Re: Heated Grips
Could you be gripping the throttle grip more tightly than the clutch side.
O2TheL
Re: Heated Grips
Post by O2TheL »
I'm convinced that my right grip is consistently warmer than the left after 20 mins or so.  Will rig up a temp monitors to confirm (because I'm a nerd).
richardbd
Re: Heated Grips
Post by richardbd »
DaygloDavid wrote: Could you be gripping the throttle grip more tightly than the clutch side.
I reckon this is more common than we think...
smileymiley
Has liked: 6 times
Been liked: 11 times
Re: Heated Grips
Post by smileymiley »
I think you'll find it's  because the r/h grip rubber is thinner as it has the throttle sleeve inside :)
Dollygray
Re: Heated Grips
Post by Dollygray »
I'm tempted to go with smiley miley - had the same problem on my last bike (dullville) and ended up rewiring the whole shebang to see if it cured the problem and nope was the answer - ended up putting it down to the thinner rubber - got the RT (2010SE) about 6 months ago and the same issue - didn't bother with the rewire and just live with it.
RTs4me
Has liked: 12 times
Been liked: 27 times
Re: Heated Grips
Post by RTs4me »
It's a common BMW 'feature' ! :)  I've experienced the same on several RTs.
Left grip is mounted onto the bars, which act as a big heat sink. Right grip is spaced off the bars by the twistgrip tube, so doesn't lose heat and hence feels hotter.
I think it's 'normal' and doesn't suggest any fault.
TCM
Re: Heated Grips
Post by TCM »
Smiley miley has hit the nail on the head! It's now just a BMW trait, my last three Hondas did the same.
If it's not broken,you didn't hit it hard enough!
