1st gear clunk
Re: 1st gear clunk
LC's have a magnetic drain plug as standard, TC's don't, although I've fitted one to mine.
They have one on the gearbox instead.
timminator
Re: 1st gear clunk
Post by timminator »
DaygloDavid wrote: "Belt & Braces", oil filter magnets, http://www.magneticoildrainplugs.co.uk/Black_Hole_Oil_Filter_Magnets.html
Perfect!  And you can get these at your local Home Depot or Lowes in USA, not sure about the UK.
BMW MOA #210438
Been liked: 484 times
Re: 1st gear clunk
RTman10 wrote:They have one on the gearbox instead.
That's where the iron comes from so it makes sense.
Our Gee
Been liked: 33 times
Re: 1st gear clunk
Post by Our Gee »
Blimey, 18 posts in less than 8 hours, some hot topic this is. I have owned 2 R1200RT's including my present Twincam. Ist gear engagement is silent, either hot or cold. In fact sometimes, especially from cold, I only partially withdraw the clutch so that I can hear and feel positive engagement.
Has liked: 90 times
Been liked: 113 times
Re: 1st gear clunk
Post by Sullivj »
Our Gee wrote: . Ist gear engagement is silent, either hot or cold.
Mine is loud enough to wake the dead. It sounds like I'm throwing a handful of bolts into an empty paint can!
It's the one thing that I REALLY dislike about the bike.
chappers2a
Bike Model and Year: 2016 RT LE
Re: 1st gear clunk
Post by chappers2a »
OurGee, if your selection of 1st gear is silent then I would suggest you have a faulty clutch and/or gearbox. Do not ride it until it has been thoroughly checked over by BMW Head Office in Germany!!! :))
chappers2a
Been liked: 46 times
Re: 1st gear clunk
chappers2a wrote: OurGee, if your selection of 1st gear is silent then I would suggest you have a faulty clutch and/or gearbox. Do not ride it until it has been thoroughly checked over by BMW Head Office in Germany!!! :) )
Or he is deaf  8)
Re: 1st gear clunk
Are these changes announced for 2017 models likely to help reduce 1st gear clunk.
"All R1200 models receive judder dampers on the transmission output shaft, along with revised selector drum actuators, transmission shafts and transmission shaft bearing."
Re: 1st gear clunk
The other explanation is he puts it in first then starts the engine.  Even my LC in silent then.  :alas:
Re: 1st gear clunk
Some say they do some say no.  I hope not.  We all need a bit of character from our bikes .
Levisp
Re: 1st gear clunk
Post by Levisp »
RTman10 wrote: Are these changes announced for 2017 models likely to help reduce 1st gear clunk.
You jest surely.
Levisp
Re: 1st gear clunk
Post by Levisp »
Our Gee wrote: Blimey, 18 posts in less than 8 hours, some hot topic this is. I have owned 2 R1200RT's including my present Twincam. Ist gear engagement is silent, either hot or cold. In fact sometimes, especially from cold, I only partially withdraw the clutch so that I can hear and feel positive engagement.
My dry clutch GS was the same. Quiet. Pity my wet clutch RT is so crappy when the rest of the bike is so good. Its called progress !
Our Gee
Re: 1st gear clunk
Post by Our Gee »
Casbar wrote:
Or he is deaf  8)
"Pardon, say again"
Our Gee
Re: 1st gear clunk
Post by Our Gee »
RTman10 wrote: The other explanation is he puts it in first then starts the engine.  Even my LC in silent then.  :alas:
No, he dosen't. Normal start procedure adopted. Bike on side stand, rider standing at side, switch on ignition, swing leg over bike, bike has gone through it's checks, start engine, feather clutch and select 1st gear and ride away in silent majesty.
Re: 1st gear clunk
Well,one of them had to be quiet.  Wonder what the problem is.
