Change in weight and feel. When did it happen?
Michaelveloz
Post by Michaelveloz »
Hello all😀
I tried a 2016 Rt today at the dealer and it felt OK. Then I tried a used 2010 and it was like night and day. It seemed so much lighter and easier to straddle (I'm 5'6"). The salesman just said they're had been some changes, but he didn't know what or when.
Does anyone have any idea at what modelle year the RT got heavier and perhaps wider?
Thanks!
Re: Change in weight and feel. When did it happen?
Michaelveloz wrote:The salesman just said they're had been some changes, but he didn't know what or when.
Was this at a BMW dealer, if so, which one?
Been liked: 26 times
Post by beemerboy9 »
To the OP
Another easy one, I'm pleased to say.......
The liquid-cooled RT was introduced in the first quarter of 2014 and there have been no significant shape or weight changes between then and the 2016 model that you tried at the dealer.
The 2010 is also a great bike which will serve you well.
tony23
Post by tony23 »
Michaelveloz wrote: The salesman just said they're had been some changes, but he didn't know what or when.
Thanks!
2010 Rt http://www.bikez.com/motorcycles/bmw_r_1200_rt_2010.php
2016 Rt http://www.bmw-motorrad.co.uk/uk/en/index.html?content=http://www.bmw-motorrad.co.uk/uk/en/bike/tour/2013/r1200rt/r1200rt_overview.html&notrack=1
Both great bikes ,either will serve you well, unfortunately the same can`t be said about your potential "salesman", find one who knows what he`s talking about.
Weight wise there is about a 25Kg increase in the LC mainly due to it being water cooled.  As the weight is lower and things like the suspension have improved it handles better.  Don't think there is any difference in their widths except the LC is narrower round your lower leg area as there are no injector bits in the way.  Height wise would depend on what seat the bikes had on but the LC low seat is 10mm lower than the TC. Find yourself a salesman who knows what he's talking about and start again.
exportman
Has liked: 16 times
Been liked: 75 times
Post by exportman »
Also the difference between a full and empty tank is noticeable, if the 2010 was empty and the 2016 full  you have nearly 50 kilos (110 lbs) difference in weight  that would feel significant.
I reckon as the salesman was so knowledgable he might have given you 1600 to try instead of a 2016.  That would explain it.  For the vast majority of us who have moved on to the LC. We find them far more agile and powerful.
leonjennings
Post by leonjennings »
Hold up guys, the best RT's ever built are the 2010-13 models.
Building sandbag fire wall as i type....... :kacsint2:
2012 SE
You are obviously in denial mode and you know full well they were stop gap models with a borrowed engine. All down to the extended development time of the LC .
Hodge
Post by Hodge »
or perhaps a finely tuned end of evolution
gogs01
Post by gogs01 »
"Hold up guys, the best RT's ever built are the 2010-13 models" "or perhaps a finely tuned end of evolution"
I'm in the process of trading a 2013 TC for a 2017MY LC. Having ridden both, I find the LC slightly easier to flat foot and, even when pushing around at the garage, it actually feels lighter than the TC. Strange perhaps, but true .....
However, if the OP decides on a TC he'll be getting an excellent model - truly a finely tuned end of evolution.
leonjennings
gogs01 wrote: "Hold up guys, the best RT's ever built are the 2010-13 models" "or perhaps a finely tuned end of evolution"
Sadly i have champagne ambitions with a beer budget :clap:
2012 SE
RTman10 wrote: Weight wise there is about a 25Kg increase in the LC mainly due to it being water cooled.
Some of the increase from 259kg (oil-head) to 274 kg (liquid-cooled) is due to a change in measurements standards.  The bikes have to be weighed with standard equipment and that included the panniers on 2014 bikes.
As it was with the TC that weighed 229kg without panniers etc.
There was some slight of hand by BMW on the K1600.  GT 314kg (no panniers). GTL 349 (with including top box). Add then onto the GT. and guess what.
I reckon with the RT it's all down to the engine because the plastic should weigh less.
guest4031
Post by guest4031 »
exportman wrote: Also the difference between a full and empty tank is noticeable, if the 2010 was empty and the 2016 full  you have nearly 50 kilos (110 lbs) difference in weight  that would feel significant.
How big is your gas tank?
Gasoline is 6.183 pounds per gallon.
