DaygloDavid wrote: How do you see where you are going.
Not only that, I wear prescription glasses with transition lenses.
Tinted visors look cool, I use a mellow smoke tinted visor with a light smoke pinlock.
As R-T Man said. Looking over the screen is the answer.
I do carry a replacement clear visor & pinlock, plus some clear lens glasses, particularly in France.
Fitted a New Aftermarket Screen
guest3954
Re: Fitted a New Aftermarket Screen
I have to wear prescription vari-focals to ride with (one of the downsides of getting old I guess) so the whole fogging thing is something I am uncomfortably familiar with. Two pieces of advice...Casbar wrote: Serious question - I sometimes wear glasses at night to ride in, how do you stop them misting up, is there a coating you can put on
1) Water will condense much more easily on a dirty surface, so give your glasses a quick clean with a microfibre cloth before you set out and you'll be impressed with the difference.
2) If your glasses are fogging up then you are not getting enough airflow through the helmet. It's a case of experimenting with the vents - and if necessary the visor position - to get enough airflow but not too much so you get cold/wet.
Regarding (2) - when I was using my Schuberth C3 I had to ride with the visor in the 'City' position all the time and at speeds below around 25 mph I had to open the visor to the first stop. (This was in part due to the fact that if you open the chin vent on the Schuberth you get substantial turbulence inside the helmet, so I never used it.) I have now switched to a Shoei Neotec. On that one I keep the exhaust vent on the back of the helmet open and have removed the chin curtain, and that's all I needed to do. If it is particularly wet I might need to open the chin vent and if I stop at the lights for more than a couple of minutes I might need to open the visor a notch. But that's all. The visor is fitted with a pinlock which stays nice and clear - it's just the glasses that cause problems.
- stayingupright
I find it less of a problem if I breath through my nose rather than my mouth ... But maybe it's just me?
Solution. System 6 Evo. 5 seconds with the chin vent open and everything is clear. No helmet dismantling required.
Just as you can't assume they're not a numpty just because they're an officer. Took me 6 months to learn that.....and 24 1/2 years for it to be proven time and again!Casbar wrote:
You can't assume someone is a numpty from posts on a forum, if that was the case a queue would have to be formed by most users of forums. 8)
That sounds a bit B & T to me . Or have I misunderstood after 32 years of being on the other side.
RTman10 wrote: That sounds a bit B & T to me . Or have I misunderstood after 32 years of being on the other side.
lol, its like in Business everyone thinks they know better than the management, pity they are not management 8)
RTman10 wrote: Thought I hadn't.
Sorry, been out for Christmas drinks, used the wrong quote, it wasn't yours I was replying to. Note to self drink less 8)
- Been liked: 506 times
"Top Tip", don't use the internet after drinking.Casbar wrote:Sorry, been out for Christmas drinks, used the wrong quote, it wasn't yours I was replying to.
I guess my poor attempt at banter has fallen on stony ground, I apologise......... (backs away slowly from the conversation after remembering this isn't ARRSE!!)
Lynxfixer wrote: I guess my poor attempt at banter has fallen on stony ground, I apologise......... (backs away slowly from the conversation after remembering this isn't ARRSE!!)
Not at all it was really good, I just screwed up my quote reply because I had been on the beer. And yet again I have been on the beer 8)
Is there a pattern emerging here?
No not really just a bad weekend
