where can i buy a canbus socket?
Re: where can i buy a canbus socket?
What about using posi-tap connectors or something similar crimp new female spades to the new wires and your away. Out of curiosity what make is the new horn?
this is what is left on the bike. ie the power from the horn switch
- Been liked: 474 times
Good idea, no cutting off of the plug, could be made good again with a little insulation tape.futterweasel wrote:What about using posi-tap connectors or something similar crimp new female spades to the new wires and your away.
https://www.youtube.com/watch?v=N64p6ndlTQ8
Scotchlok connectors do a similar job, https://www.youtube.com/watch?v=WFdVkSaHRpU used them for installing tow bar electrics on a car.
You could give this Guy a try ? http://www.ebay.co.uk/itm/322351308828? ... 1436.l2649
I have BMW part No61337159421 Horn Low brand new in the box will fit straight on to your bike and just plug in yours £20 posted (if you are in UK)
I believe you want the "male" portion of the plug, your dealer should be able to supply that
I soldered the spade connectors to the wire pigtail and attached to horn
For £8.56, this "sounds" like the best solution.T6pilot wrote:I believe you want the "male" portion of the plug, your dealer should be able to supply that.
I soldered the spade connectors to the wire pigtail and attached to horn.
- blokeonthemove
I know the BMW ones are expensive but the scotchlok connectors are not reliable with fine wire and once buried in the fairing are a real pain if they fail owing to wet or strain. I used the bare wires strengthened by a bit of solder then poked into the BMW female side and taped up on a previous GS, it works but it's a bodge, you won't be happy . You just can't fill the bike with crappy bodged up fitments.
thanks all
i have ordered this
http://www.ebay.co.uk/itm/322351308828?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
and some of those posi-tap things, if that doesn't work.
if all else fails i will just botch it with paperclips, twisted bits of wire and gaffer tape, which is my usual method for these things. its only a horn, and i can never find the horn switch quick enough anyway, as it is located in such a stupid position on the handlebars!
i have ordered this
That's a good price, Rainbow BMW want £9.05 for the same item, http://www.rainbowbmw.com/BMWETK/Produc ... 011902.phpSullivj wrote:I think BMW sell them for £3.99 each. It's the last part number in the photograph.
Will a 3 pin GPS plug fit in a 2 pin horn socket.ds99 wrote:I have ordered this, http://www.ebay.co.uk/itm/322351308828? ... 1436.l2649
Is 28 now 29 posts a world record on where to buy one little cable.
RTman10 wrote: Is 28 now 29 posts a world record on where to buy on little cable.
People buy bikes with less advice!
