Pairing Schuberth C3 Pro to '12 RT
stablesgroup
I've run through all the steps in the manuals, watched the Youtube videos, etc. etc. to pair and have yet to be successful. I keep getting "Unable" or "Failed".
Anyone have any tricks or advice on what I'm doing wrong?
Thanks in advance!
Thanks in advance!
stablesgroup
Re: Pairing Schuberth C3 Pro to '12 RT
It's a 2012 R1200RT w/Audio Communication package incl. Bluetooth Interface Control, Luxury Pkg. and Cruise.
I can only suggest you clear out all previous links from the bike and the headset and try again. If that fails try to connect your headset to another system to try and discover if it's working. You could try the same with your bike with a different headset.
stablesgroup
Yeah...I just thought someone might have had the same issues pairing the C3 w/the RT's communication package. I think there's an issue between Schuberth and BMW.
Think the C3 Pro is a Scala BT unit. I have paired two different Scala BT with my 2014, the older G9 and the new Packtalk, both worked and work fine.
Try one of the US RT sites and ask the question or do a search, if there is a problem, someone will have come across it.
So did a search and it would seem it can be done with the 2014 on RT, so not sure about the older bikes
https://forums.bmwmoa.org/showthread.ph ... ing-Issues
Audio unit on the 2012 bike goes back to 2010 so might have issues with a new headset.
stablesgroup
