Nav V
- stayingupright
Re: Nav V
Me too! ... Thanks
Quite a long update for me. It took about 45 minutes.
- stayingupright
Re: Nav V
RTman10 wrote:
45 min, a long update, I wish. Just done mine 5 HOURS.
Are you still on dial-up?
Re: Nav V
I had to get my nearly new Nav V replaced under warranty.
Registered and updated it, probably in less than 45 minutes - quite an achievement for someone with my level of computer expertise.
I'll find out if the updates are up to date next week when I'm heading down through England / France / Spain (avoiding tolls).
Re: Nav V
Considering buying a Nav V, just a couple of questions. My 2015LC has not got the audio package but has speakers and blank switches. Does Nav 5 connect to these speakers, or are they just covers ,is there a speaker built into Nav V unit itself , or do I need helmet communication??? If I need connections to helmet, any recommendations ( I ride solo, so pillion comms is not desperately needed and I have Arai helmets ) Thanks in anticipation.
scunny1 R1200RT LE 2015
Re: Nav V
I have an LC without audio, my brother has one with audio. We both have BMW helmets with the BMW Bluetooth communicators. As far as I know, the satnav can't communicate via the audio system speakers.scunny1 wrote: Considering buying a Nav V, just a couple of questions. My 2015LC has not got the audio package but has speakers and blank switches. Does Nav 5 connect to these speakers, or are they just covers ,is there a speaker built into Nav V unit itself , or do I need helmet communication??? If I need connections to helmet, any recommendations ( I ride solo, so pillion comms is not desperately needed and I have Arai helmets ) Thanks in anticipation.
I can't help with a recommendation for a Bluetooth device to fit your Arai - sorry.
Re: Nav V
I think you'll find your bike has speaker covers but no speakers. I also think you'll find they're not blank switches, just moulded covers over empty holes.
Why would they install speakers or switches on a bike wth no audio system??
The Nav5 has no speaker or audio-out jack-plug, so you're down to a choice of bluetooth headset. You will find plenty of threads on here with a variety of opinions on their merits. Good luck choosing!
Re: Nav V
I have a 2016 RT without the audio package. The speaker covers are just that - there are large voids behind them where speakers could go. The buttons on the left lower side are blanks where buttons would go - the wiring behind has also been removed.
The Sat Nav will link through any Bluetooth helmet system.
Re: Nav V
You have two choices for connecting to your Nav and both are Bluetooth. Either a full Bluetooth headset of whatever make you wish or a wired system like an Autocom with a Bluetooth dongle attached. For me the advantage of the wired system is I can use more than one helmet as the headsets are relatively inexpensive and everything is bike powered. You don't get bike to bike though.
