Mounting kits for a Garmin 340LM
BBT600
Post by BBT600 »
Please see the attached photos of a RAM type ball/bolt for mounting my Garmin. This method uses one of the RT handlebar bolt holes, and uses a bolt with a RAM ball on the end for mounting a satnav type device. Could anyone provide a link to where I can buy one.
Also, the handlebars are secured by 4 bolts, but instead of using allen headed bolt, they use a kind of star headed bolt. Please see attached image 2164. What is the correct term for this type of bolt and what size are used on the RT bars?.  I have a similar type drive, but largest I have is stamped as T30. This isn`t big enough to fit this size of bolt head.
BBT600
Re: Mounting kits for a Garmin 340LM
Post by BBT600 »
Ah - Torx. I got that bit  :thumbs:  What size are they though?
BBT600 wrote:Torx. What size are they though?
T45 (M8 x 30mm)
BBT600
Post by BBT600 »
Thanks David.
BBT600 wrote:Could anyone provide a link to where I can buy one.
This looks very similar, http://www.ebay.co.uk/itm/BMW-R1200RT-S ... 1789549570
BBT600
Post by BBT600 »
Thanks again David. I don`t suppose you know the thread length of these bolts?  Or if anyone else knows please advise thanks.
BBT600 wrote:I don't suppose you know the thread length of these bolts?
RealOEM says, M8 x 30mm, if there is any doubt, remove one & measure it before ordering the ram mount.
