Help on paint colour
Greetings,
I need some help with the colour code for my MY16 RT. The colour is NC9 ebony metallic, but I don't know the colour code to paint the top box.. anyone has it?
Make Life A Ride #makelifearide
all these moments shall be lost, like tears in the rain...
Re: Help on paint colour
I found, by accident, the paint code inside the upper right fairing. Label attached to fairing had the code. Note be careful removing the fairing the tabs are prone to breaking easily
- timminator
- Been liked: 2 times
There is also a website for colorite paints that has all the codes. You simply put in the year, make and model of your bike and it will return the information.
http://www.colorrite.com/
BMW MOA #210438
It doesn't have ebony metallic... searched ittimminator wrote: There is also a website for colorite paints that has all the codes. You simply put in the year, make and model of your bike and it will return the information.
I have just had my top box resprayed in the same colour. I gave the same code to the guy (it's only a small 2 man business) and he got the paint mixed by a small local supplier in 4 hours in Middlewich (Cheshire).
I am away from home at the moment but when I get back I will look at the jar (which I still have) and let you know the full code that is on the top.
Yes that code I need. Thank you mate!!Taz wrote: I have just had my top box resprayed in the same colour. I gave the same code to the guy (it's only a small 2 man business) and he got the paint mixed by a small local supplier in 4 hours in Middlewich (Cheshire).
Does anyone know the paint code for the engine block of a 2014 Rtlc? I have picked up a stone chip and want to cover it before it gets worse.
I finally did it..
Wow, looks good. Sorry I did not get back to you sooner as I only got back yesterday from nearly three weeks away for work. Funnily enough, I just went into the garage to take a photo of the paint and then I saw that you had managed it anyway.
Just for fun, what was the paint code you used? Mine is C:62930 R:/F:636908
Well I don't have the code, since my paint shop manager found it for me. No problem mate !! Result is satisfyingTaz wrote: Wow, looks good. Sorry I did not get back to you sooner as I only got back yesterday from nearly three weeks away for work. Funnily enough, I just went into the garage to take a photo of the paint and then I saw that you had managed it anyway.
