RT (Twin Cam) - Air Filter Replacement
MAX BMW Garage R1200RT Air Filter Replacement
https://www.youtube.com/watch?v=cLXZ6AFTeXA
(Only need to remove the RHS Panels).
beemerbaz
Re: RT (Twin Cam) - Air Filter Replacement
Post by beemerbaz »
[emoji106] Max BMW do some good videos, helped me in the past.
Checked the Air Filter whilst the panels were off, although the Service Interval is every 12,000 miles, the Filter was quite dirty after just over 3 years & 6,860 miles.
Decided to replace the Filter as they are not that expensive.
DaygloDavid wrote:Decided to replace the Filter as they are not that expensive.
A BMW Air Filter costs £19.75, OPIE Oils do one for £10.99 + £2.75 P&P, http://www.opieoils.co.uk/p-89201-mahle ... -part.aspx,
a saving of £6.01, I know where I'll be buying my next one from.
The BMW Part No. is 13.71.7.706.414, this checks out with the MAHLE No. of LX 984/5.
Catfunt
Post by Catfunt »
Two Hi-flo HFA7914 air filters for £19. I change them annually
---- 2013 R1200RT SE ----
Have used Hiflo Air Filters on my XJ650.
Has liked: 96 times
Been liked: 141 times
Post by Sullivj »
I got two for £20.14 (with free delivery) from Amazon.
Exactly the same as the original BMW one, albeit cheaper.  Thanks for the tip David.
My bike has only done 5,000 miles, but as you can see, it was quite dirty.
Sullivj wrote:Exactly the same as the original BMW one, albeit cheaper.
It can't be the same, hasn't got BMW on it and it's half the price.
I put a Mahle filter in mine when I serviced it over winter, It had a MWR one in it when I bought the bike.
Has liked: 96 times
Post by Sullivj »
That MWR one looks a little odd. Not seen one like that before.
I'm looking to purchase either a Mahle LX984/5 or Hi-flo HFA7914 air filter, can anyone recommend a supplier, (I don't use ebay).
Found this HFA7914 on Amazon, https://www.amazon.co.uk/B%C3%9CSE-HFA7 ... ds=hfa7914
Have ordered two Hi-flo HFA7914 air filters for less than the price of one from BMW (£22.92).
David. wrote:Have ordered two Hi-flo HFA7914 air filters for less than the price of one from BMW (£22.92).
The two air filters arrived today, how's that for next day delivery.
This is what it says on the box,
"Hi-flo air filters are specifically designed to be a direct replacement for the OE filter.
To maintain your motorcycle's peak performance it is advisable to replace your air filter regularly, preferably at the same time you change your oil filter."
The BMW service interval is every 12,000 miles, based on the above, plus from experience & cost, I'll change the air filter around every 6,000 miles.
David. wrote:"To maintain your motorcycle's peak performance it is advisable to replace your air filter regularly, preferably at the same time you change your oil filter."
Once again, the air filter has been changed after 6,000 miles.
It gets even better, found a new supplier, can get a HFA7914 air filter for £5.93, that's nearly 75% cheaper than a BMW one.
Has liked: 96 times
Post by Sullivj »
Good find David. Where's that?
