Problem connecting a Nav V
I have just tried connecting a Nav V for a map update.  On two separate computers  I get a message that the USB devise is not recognised even though the Nav screen shows it is connected but then reverts to the normal screen, After  numerous attempts my tablet told me the device had exceeded the available power output of the terminal and the PC said the connection had failed and the device must be defective. Anybody had similar problems.  The Nv V is working normally by the way.
T6pilot
Re: Problem connecting a Nav V
Post by T6pilot »
Make sure your using the Garmin supplied cable, I had the same issues using non factory cable
stayingupright
Post by stayingupright »
I do find that some of my cables work and some don't.
Turns out you can get usb cables that power stuff but are not able to transfer data.
T6pilot wrote: Make sure your using the Garmin supplied cable, I had the same issues using non factory cable
It’s the correct supplied cable for sure and I have used it on earlier updates. I’m wondering if it’s a battery problem.  It had been allowed to flatten and had to be plugged unto a bike to wake it up.  It’s showing charged now but might just be knackered.
bighopper
Post by bighopper »
Did you try using Garmin express, even though got the not connected message?
The NAV V connects using a different method (can't remember what it's called) to Windows machine & NOT MASS STORAGE as you see other devices.
bighopper wrote: Did you try using Garmin express, even though got the not connected message?
Yes always use Express which incidentally has crashed this afternoon.  Gets better all the time.
Looks like T6pilot and staying upright are correct.  I have discovered the cable was one bought to replace the lost OEM one.  My Spyder is fitted with a Garmin 590 and although it’s cable is shorter and looks thicker the Nav V is now loading the maps with it. Thanks chaps.
Does this mean that the Garmin cable fits the BMW Nav V.
stayingupright
Most of my usb micro and mini cables will only charge. I had to buy a few good ones that will charge and data transfer for my pc to even recognise them.
