TOP CASE DISASSEMBLY
jackronner
- Has liked: 2 times
- Been liked: 12 times
Just finished 10k miles around the US and Canada, and the top case lid didn't pop off on my 2005 RT, but the left side sliders/posts in the base don't move to engage the lid's "teeth", and the seal on that side isn't water tight. Right side works fine and holds it shut securely. I assume that the sliding posts are actuated by a cable system, but it looks as if you have to remove the inner shell to expose the slider mechanism. However, it would appear that parts of it are held on by rivets rather than screws, etc. Blow up diagrams don't help, and they only show a photo of the lock mechanism, not a diagram. Given that the case costs about as much as a used car, don't want to experiment on it. Anybody have any experience with this?
Re: TOP CASE DISASSEMBLY
I took mine apart to rekey the lock. The rivets do not need to be removed to take out the inner shell.
Basically remove every screw you can see plus the nuts under the handle and the inner shell will come out.
jackronner
Thanks for the info. I'm guessing that there are two actuating cables leading to the left and right sides? Probably cost $300 apiece.
From memory (I only did it three weeks ago) they are not Bowden cables, they are steel bands about half inch wide. I didn't actually pay much attention to the mechanism as I was only after the lock barrel; from what I saw there shouldn't be much to go wrong that isn't easily repairable.
Does this thread help at all?......scroll down it for pics.
http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=831470&page=2
Pete
Pete
jackronner
Wow, I wasn't hopeful of getting any response at all! Thanks again to all, and the pics were very helpful, Milleplod.
jackronner
I'm the OP, and it just occurred to me that I may not have to remove the inner shell of the top case. My issue is the left side locking sliders aren't actuated by the handle, so I'm wondering if that can beg addressed, or at least assessed, by removing the handle alone (two screws and two nuts)? Would that expose he workings? No parts diagram I've seen shows the relevant parts, or even the handle.
The mechanisms are actuated by a rack and pinion type system, with the pinion on the handle and rack sticking through the case. Since one rack operates all of the lid locks (and a second operating the case-to-bike mech), and some of those are working correctly I very much doubt you will see much just by removing the handle. Having said that, you have to remove some of it anyway so it's not going to hurt to have a look.
You should be able to have the case disassembled and re-assembled within a half hour with a torx key and a 8mm ring spanner, even if you don't fix the problem, you'll know for certain what it is.
jackronner
- slparry
- Has liked: 12 times
- Been liked: 35 times
