Gear Change lever
matgriff
Gear Change lever
Post by matgriff »
Hi, does anyone know if the gear change lever from a 2010 onwards R1200RT will fit my 2005 RT ??
Iv'e not ridden my RT much after getting it last November, but I find that I need a wider gear change lever with my new boots, both my mates have 2010 RT's and I noticed that the gear lever is wider (about 15-20mm) so that would be easier to get my foot under. I guess BMW decided the original one was a bit too small and changed it on the later model ?
It also looks like the later one is adjustable, at the back of the bit that the rubber fits on to ?
Thanks
Mat
Re: Gear Change lever
matgriff wrote:Does anyone know if the gear change lever from a 2010 onwards R1200RT will fit my 2005 RT.
The (splined) selector shaft (#3) has the same part no. on both the 2010 and 2005 RT's, http://www.realoem.com/bmw/enUS/part?id ... 3417693523, therefore, don't see why the 2010 shift lever wouldn't fit a 2005 bike.
2010 shift lever, http://www.realoem.com/bmw/enUS/showpar ... Id=23_1107
2005 shift lever, http://www.realoem.com/bmw/enUS/showpar ... Id=23_0964
milleplod
Post by milleplod »
matgriff
Post by matgriff »
Thanks for that,also just seen that there's a guy on ebay who does extenders for the gear change & brake levers for the 2005-2009 models :-)
Mat
Reaper999
Post by Reaper999 »
matgriff wrote: Thanks for that,also just seen that there's a guy on ebay who does extenders for the gear change & brake levers for the 2005-2009 models :-)
Mat
I've got extenders on both gear change and brake from "godzillabikes" on E-bay and they work really well in my opinion.
matgriff
Post by matgriff »
That's exactly who I've bought them from :-)
Mat
