Protecting plastic bits - temporarily
Re: Protecting plastic bits - temporarily
Paint supply stores have a brush on plastic that you might be able to use. When done your risky ride (dirt road trips too) you just peel it off
- timminator
- Been liked: 2 times
The course was great, and best of all no drops! Lots of very tight turns, u-turns, and some awful thing they called the iron cross which was a cross-shaped series of cones where you did a u-turn in each arm of the cross, reversing direction each time. But I did install very attractive rubber floor tiles on the panniers as a precaution.
[attach=1]
[attach=1]
BMW MOA #210438
- timminator
It's so genius. I'm sure the boys at wunderlich will steal my idea.Steve F wrote: Ooh! Very fetching accessorising!!![]()
BMW MOA #210438
guest2383
Would these normally be fitted by a BMW Technician or a Carpet Fitter?
geordielad wrote: Would these normally be fitted by a BMW Technician or a Carpet Fitter?
- Has liked: 136 times
- Been liked: 204 times
Got any videos of the course?timminator wrote: The course was great, and best of all no drops! Lots of very tight turns, u-turns, and some awful thing they called the iron cross which was a cross-shaped series of cones where you did a u-turn in each arm of the cross, reversing direction each time. But I did install very attractive rubber floor tiles on the panniers as a precaution.
[attach=1]
