Menu Switch
buzz
Menu Switch
Post by buzz »
Hi,
My Menu switch is beginning to get a little sticky, on my R1200Rt 2016 what's the best way of sorting this out? WD40 or some other electrical spay
Regards
Chris
PeteM
Re: Menu Switch
Post by PeteM »
buzz wrote: Hi,
Regards
Chris
I wouldn't use WD40 - will just collect dirt. Tiny bit of silicon spray might work OK, or possibly some switch clean but not tried either
Vince Prince
Re: Menu Switch
Post by Vince Prince »
The menu switch on my '16MY got sticky and was replaced under warranty. The replacement switches screen icon matches those from MY >18. Don't know if that is mere co-incidence or a change in switch innards.
Re: Menu Switch
Contact cleaner.
Re: Menu Switch
This thread from a K1600 forum, https://www.k1600forum.com/forum/bmw-k1 ... ilure.html shows the construction of the switch.
(Ignore the white wire, it's a repair).
"Switch cleaner, as has been reported, may cause a temporary fix since, once again, the evaporating solvent could have a cooling effect. There are no exposed contacts to clean; each button is sealed with a rubber boot against the elements and against switch cleaning fluid."
Re: Menu Switch
David. wrote: Image
This thread from a K1600 forum, https://www.k1600forum.com/forum/bmw-k1600-lighting-electrical/31929-anatomy-lefthand-combination-switch-failure.html shows the construction of the switch.
What was the actual fix from that link? I can't be arsed reading loads of posts on tap talk to find out!
Re: Menu Switch
simbo wrote:What was the actual fix from that link?
"Windscreen "up" button wouldn't work".
Re: Menu Switch
David. wrote: "Windscreen "up" button wouldn't work".
Yeah, The OP's got a 'sticky' menu switch, I'd be looking at a bit of contact cleaner and spray of furniture polish/silicone spray to clean & lube the button's moving action up.
Re: Menu Switch
The clearance between the menu (rocker) switch & the switch housing is there to be seen. The windscreen switch is of the same design.
The sealed buttons beneath the switch may be the problem.
Vince Prince wrote:The menu switch on my '16MY got sticky and was replaced under warranty.
Re: Menu Switch
David. wrote: The clearance between the menu (rocker) switch & the switch housing is there to be seen. The windscreen switch is of the same design.
Bags of room, park a bus in there! lol OP said button was 'sticking' NOT 'not working'.. if something is 'sticking' clean and lube to prevent further sticking. If something 'isn't working' clean and lube, and if that doesn't resolve the problem? remove for further investigation towards electrical contacts.
buzz
Re: Menu Switch
Post by buzz »
Many thanks for the reply's, the switch is working, but feels just a little sticky
Fafa31
Bike Model and Year: R1200RT 2011 Dohc
France
Re: Menu Switch
Post by Fafa31 »
Hello All,
As lot of R1200RT owner's, I met issues with my left-hand combination switch. Las weekend I opened it. Inside I figure out switch push button with broken springs and other with no more electrical contact. I understood it was inserted inside plastic part fixed on direction bar and surely solded with electronic solder flux or glue.
My question is does anyone can give me the reference of this switch push button mounted on R1200RT Dohc 2011? I would like to replace it, it will be cheaper than change all part.
Many thanks and sorry if my English is not perfect 🙂
