Garmin Express update
Been liked: 472 times
Re: Garmin Express update
jjwill wrote:Version 6.16.1.0 now available.
Tried to update from v6.16.0.0 to v6.16.1.0, it failed.
Had to go through the rigmarole of uninstalling v6.16.0.0 to then download v6.16.1.0, good old Garmin again.
austavla
Bike Model and Year: 2015 BMW R1200RT
Norway
Post by austavla »
Updated to version 6.16.1.0, no problem at all.  ^-^
austavla
Norway
Post by austavla »
Updated to version 6.17.0.0, no problem at all.
Once again, had to uninstall v6.16.1.0, got a message "Microsoft.NET Framework required for Garmin Express setup". Something to do with Windows 7, when I'm on Windows 10, it's beyond me.
The GE System Requirements for Windows are, "Windows 7 SP1 or newer, Microsoft .NET 4.5.2 (included)"
Successfully downloaded Garmin Express v6.17.0.0 from Garmin website.
jjwill
Been liked: 5 times
Post by jjwill »
Windows 10 and updated. Thanks
v6.18.0.0 now available, still getting the same error as posted above. Once again, had to uninstall the previous version and download the latest.
PeteM
Post by PeteM »
David. wrote: v6.18.0.0 now available, still getting the same error as posted above. Once again, had to uninstall the previous version and download the latest.
Have you tried doing a stand alone install of the required .Net library?
https://www.microsoft.com/en-gb/download/details.aspx?id=42642
PeteM wrote:Have you tried doing a stand alone install of the required .Net library?
I'm using Windows 10 which is not listed in the Microsoft link.
PeteM
Post by PeteM »
You should still be able to install without any problem. If that does not fix the problem you could even try installing the dev pack https://www.microsoft.com/en-us/download/details.aspx?id=42637
Thanks for your suggestions, I'm rather nervous when it comes to PC matters, I usually get a man in.
Meanwhile, if necessary, looks like I'll have to continue with the "uninstall" then "download" method, it seems to work for me.
PeteM
Post by PeteM »
I wouldn't worry too much about installing the MS library, as they come from MS they tend to be pretty reliable, will only install if it does not break anything and uninstall reliably.
austavla
Norway
Post by austavla »
Version 6.19.2.0 is now available. :)
Thanks for the "heads up", update failed again.
Had to uninstall v6.18.0.0, then as recommended by my PC Guy, shutdown & restarted the PC. V6.19.2.0 now downloaded ok from Garmin website.
Will be interesting to see whether or not, when the next update is available, this action solves the problem of failed GE downloads in the future.
Version 6.19.3.0 is now available.
David. wrote:Will be interesting to see whether or not, when the next update is available, this action solves the problem of failed GE downloads in the future.
Well that didn't work either, had to uninstall v6.19.2.0 and download v6.19.3.0.
It's beyond my PC technical ability.
