Help Identifying Power Sockets
Hi all...trying to learn what i can about my new-to-me 2013 R1200RT. Can you please help me identify these power sockets under the front fairing and behind the seats?
Thanks
Thanks
- Been liked: 25 times
Re: Help Identifying Power Sockets
Bernman, is your machine an ex-authority vehicle? I am asking because it appears to be painted white and has an additional cooling fan.
- Been liked: 472 times
Not 100% sure by any means, could this be for TPM or an alarm box which would be tucked behind the seat.
Is the bike fitted with a BMW Nav. cradle like this one.
The two white connectors look very similar to these.
I believe the bike is stock and with no police equipment...the bike is actually silver but the tail rack in the picture makes it look white. I’ll have to look into the oil cooler situation. The bike does have the nav cradle with the 4 buttons...does the cradle use both the white plugs?
Thanks all...Happy New Year!
Bernman wrote:The bike does have the nav cradle with the 4 buttons, does the cradle use both the white plugs?
If the bike is fitted with a factory audio system, the 2 pin plug is used for audio (mono) output and the 3 pin plug is for power, (only 2 pins used).
Thanks David...hugely helpful! Any recommendations on repair or maintenance manuals that would be good to have? The dealer repair manual may be too extensive for a noob like me.
Haynes Manual, https://haynes.com/en-gb/bmw/r1200gs/2010-2012Bernman wrote:Any recommendations on repair or maintenance manuals that would be good to have?
Just realised within this photo,
it's showing the headlight unit bulb covers.
Sorry for any confusion, silly me.
The connection highlighted to the top right will be for the headlight unit itself.
Any further thoughts on the one behind the pillion seat?
Hi David...i took a bunch of fairing off today to install some cylinder protectors and was able to see the top plug was for all the headlights and there definitely no aftermarket oil cooler. You helped figure out the navigation plugs (thanks!) but I noticed there’s actually a third capped plug on the same bundle as the nav plugs, so now i want to figure out what that one does. I still don’t know what the tail plug is for.
Bernman wrote:I noticed there’s actually a third capped plug on the same bundle as the nav plugs, so now I want to figure out what that one does.
Is the bike fitted with a factory audio system. If not, then my interpretation of the Haynes manual wiring diagram would suggest that the third capped (3 pin) plug is for audio.
Bernman wrote:I still don’t know what the tail plug is for.
This looks like a 2 pin connector. The Haynes manual wiring diagram says, "Note - where anti-theft/tyre pressure control unit is not fitted, the CAN bus is terminated with a terminating resistor."
Can the socket/plug be prised open to confirm.
It appears to be the Canbus connector for the DWA (alarm) and/or RDC (Tire Pressure Monitor System) module:David. wrote:
Does your bike have either/both of those options? The module will be located under the luggage rack area and looks like this:
Last edited by rangemaster728 on Thu Jan 02, 2020 3:54 pm, edited 1 time in total.
Hi David...I'll take a look after work but my bike does not have a security system or tire pressure monitor so it looks like it supports just power to either. From the other thread, it looks like the capped connector under the front fairing is for auxiliary lights then?
Thanks,
Gary
Thanks,
Gary
Bernman wrote:From the other thread, it looks like the capped connector under the front fairing is for auxiliary lights then?
David. wrote:This photo is of a 2017 LC.
SurfCity16RT wrote:That is for your auxiliary lights.
