Exhaust valve seized
Beagle
Re: Exhaust valve seized
Post by Beagle »
I thought the cat was part of type approval. Im suprised if BMW approve the fitting without it.
Been liked: 484 times
The Akrapovic silencer is the only one approved for use by BMW.
Don't know if these headers are approved for use by BMW. The observation is that the valve has been retained.
If fitting the non-cat. version Akrapovic recommend the following.
When installing optional headers E-B12R7, remapping the ECU is recommended in order to prevent »check engine light« warning signal and achieve optimized performance and throttle response.
THIS PRODUCT DOES NOT MEET EMISSION COMPLIANCE REQUIREMENTS FOR STREET OR HIGHWAY USE.
Beagle
Post by Beagle »
“ THIS PRODUCT DOES NOT MEET EMISSION COMPLIANCE REQUIREMENTS FOR STREET OR HIGHWAY USE.”
Exactly!
I wonder if the Akrapovic header with a catalytic converter is approved for use by BMW.
Been liked: 46 times
David. wrote: Akrapovic manufacture exhaust headers for the 1250, https://www.akrapovic.com/en/moto/products/BMW/R-1250-RT?brandId=44&modelId=994&yearId=5778
Options are available in Stainless Steel or Titanium. In both cases, they have an exhaust valve, with or without a catalytic converter.
Interesting that the exhaust valve has been retained in all cases.
I wonder if they have had to do this to have them approved for use by BMW.
"Featuring exhaust valve for improved rideability in lower rpm."
Check out the installation instructions to see photos of the different Akrapovic v's BMW exhaust valve.
https://d1sfhav1wboke3.cloudfront.net/ImageServer/Apim2media/Documents/20687/a97ade48-8c42-4717-85de-617698a7ee92.pdf
That link is for a GS and GSA, different headers, is there one for the RT as well? Could look myself I suppose :)
guest4915
Post by guest4915 »
It's a bit late after you've traded it
These Akrapovic installation instructions cover all R1250 models,
https://d1sfhav1wboke3.cloudfront.net/I ... 358c0b.pdf
David. wrote: These Akrapovic installation instructions cover all R1250 models,
https://d1sfhav1wboke3.cloudfront.net/ImageServer/Apim2media/Documents/20688/a3e289b7-8b0f-41c1-94f4-507ea6358c0b.pdf
Great, its just they show the GS headers, which are different to the RT. But let's be honest, its not rocket science to change headers - is it
Has liked: 116 times
Been liked: 268 times
Not for anyone with any mechanical skills it's not, it's a very straightforward job.
Beagle wrote:Took silencer off to lube the flapper pivots.
What lube was used, was the flap seized and is it free now.
Beagle wrote:Service light now comes on but will have to wait till dealer will do it.
Can the service light be reset with the GS-911, https://www.youtube.com/watch?v=HmYQDuQyPFA
Beagle
Post by Beagle »
Borescope Pictures of Flapper Valve and Cat
That flap looks very clean, no sign of carbon or lubricant.
Beagle
Post by Beagle »
I only use Shell Nitro both in the bike and the X1.
David. wrote:What lube was used, was the flap seized and is it free now.
Beagle
Post by Beagle »
Wasnt seized just relieving boredom. Used Graphite/Copper spray.
