What grease on final drive splines
Hi Guys Im new here and just bought a 2015 RT LE
Im going to change the final drive oil in my bike as ive no idea if its been done recently Ive got the oil and have watched youtube videos on how its done but cant seem to see what grease is used on the drive shaft splines
thanks
Rob
thanks
Rob
Re: What grease on final drive splines
Honda Moly 60 is the absolute best, reviewed by many and used at many different dealers. ..but I hear it’s unfortunately discontinued if anyone can find it or a substitute, I’d like to know too as I’m running low.
Blueboy
- Been liked: 4 times
Last 2 times I did mine I used :
Honda HN 08798-9010 MOLY PASTE (M77)
https://www.amazon.com/dp/B0083BWUYW/ref=cm_sw_em_r_mt_dp_U_7f3LEbXBFXQ27
https://youtu.be/W45HnUI9ljQ
The manual calls for a hard to find spline lube... Castrol Optimol TA. I've used it for 10yrs and have found that IF and WHEN moisture gets into you the Paralever tunnel it does not protect very well against rust or seizure between the drive shaft and the FD splines.
Recently I've started using the same as the previous posters...the Honda M77. It is easier to find and a little goes a long way...one little tube will probably do 20 services.
If you have not done the service on the WetHead before, here is a video I made to cover the Final Drive service.
https://youtu.be/c1_1gPRA274?t=946
Or, you can start the complete series of 6 videos from the beginning.
https://www.youtube.com/watch?v=0exJbyMnGQg
Please be sure to click on the "Show More" in the Details of each video to see an explanation or special links to tools used or work assists to complete the service.
Hope this helps!
Hope this helps!
Cheers Guys
Boxflyer I watched all your youtube videos this morning very informative also thanks for the reply ill order the right stuff and do a complete service on the bike
although its got full service history its not all BMW so ill do it properly so i know its done
its on 14k miles so better safe than sorry
Rob
Rob
For those in the US, Beemershop sells a specific spline lube in various sizes. I don't know if they ship overseas.
https://www.beemershop.com/product/ts-60-spline-lube.html
...Dan
Blueboy wrote: Honda Moly 60 is the absolute best, reviewed by many and used at many different dealers. ..but I hear it’s unfortunately discontinued if anyone can find it or a substitute, I’d like to know too as I’m running low.
https://www.tegiwaimports.com/honda-moly-60-m-77-assembly-paste-grease-75g-2-65oz.html
- Been liked: 474 times
This is what BMW use for the spline, Castrol Molub-Alloy Paste TA.
https://www.online-parts.co.uk/bmw-spar ... Paste.html
Available from NN's, Castrol Molub-Alloy Paste White T (100g) tube (nippynormans.com)David. wrote:This is what BMW use for the spline, Castrol Molub-Alloy Paste TA.
Recently replaced the FD unit and shaft on my XJ650. A.n.other very kindly provided some Honda Moly 60 to lubricate the splines prior to assembly.
My understanding is that this Honda product is no longer available and may have been replaced by M77.
The BMW (Castrol) recommended product is Molub-Alloy (TM) Paste TA, previously named Optimol (TM) Paste TA, see Product Data, BPXE-9T98FZ.pdf (castrol.com)
Smith and Allan at Darlington sell the latter on ebay for £10 or collection in store, Castrol Optimol Paste TA High Temperature Hot Screw Paste Anti-Seize 100g Tube | eBay
This is around £5 less than purchasing the same stuff from BMW.
- Has liked: 1401 times
- Been liked: 403 times
While ive always recommended Smith and Allen for their oils and grease but in my case regarding shaft drives I've always used HT marine grease and paste. Not only is it waterproof but is meant to be able to stand higher temperatures than normal car/bike HT oils and paste. I also use grease for the head and swingarm bearing. Can cost a little more but my tub has lasted over 5 years and still has plenty left for a few more years.
