michaelc2710 wrote: So to recap, what is the flap for.......
What Flap????? :silence:
7vwh wrote: [quote author=Casbar Sounds like you may have another issue going onYes you are right you still hear the servo click, but its not doing anything as it can't go through its full cycle.
Possibly, I just posted some info for the benefit of other owners. Not had the fuse error since I freed up the flap. Could just be coincidence at the end of the day![]()
Sprintgull wrote: I think we need to set up a rota for checking Beagle's welfare. If BMW find out that he's found a way to thwart their little money-making scheme of making people buy new headers then, well, you never know. You know what I'm sayin'....
Casbar wrote: My mates r1250RT had its headers replaced yesterday, stuck exhaust flapat 8000 miles
MikeS wrote:
Thanks. That's cheered me up no end.
When switching the ignition on, the sound is likely to be the servo motor rather than the valve itself. A physical check of the valve every now & then might be a good idea.B787MECH wrote:I always listen for the valve cycling when I first switch on the ignition.
BoB21 wrote: Mine 37000miles no problems. Maybe they need to be used?
simbo wrote:
It's to provide entertainment, everybody loves a bit of flap action.
[attachimg=1]
David, I’ve now replicated your work and the video... it worked amazingly well. My exhaust flap is now moving freely and the servo close and opens it when the ignition comes on. I’ve also used the graphite power.David. wrote: You can't beat a nice little video, https://www.youtube.com/watch?v=MtcUZn_T6Oc
