Today didn't pan out quite as expected.
Rod
Post by Rod »
Any ride that gets you home without tarmac surfing or sudden deceleration events is a good ride. However there are some days and rides that make you think “Should have stayed in bed”……
Today the RT has been ungrateful, considering it was MOT and Road5GT day. Battery had had a little top up in the week, thanks to C19 its done few miles this year.
It all went downhill after I took the bike out of the garage, locked it up and went to get kitted up [ flats and garage block]. Weather is like being in a cloud, warm and 99.9% humidity – melting as I reach the bike.
Talk to neighbour (forgetting the disk lock is on – you know where this is going)
Start bike – it won’t blip from idle, this causes it to stall – that’s new!, put it down to forgetting the idle sync throttle stuff after having the battery off as it seems to clear. Pull off, travel 2 feet, stop suddenly and the RT decides to have a rest and a little lay down [See disk lock]. With only some twinges from making it a controlled drop, there was no stopping it, I picked it up and went to sort the disk lock, introducing the sleeve of my jacket to the hot down pipe. Hello hole.
Check the bike over and head off for MOT. Cross Surrey, some narrow lanes, gravel, mist, rain, steamed glasses, ¾ of the way there some nutter started shouting in my helmet “You are ****ing mad I can’t see a thing”, 30 mph can be exciting.
Bike passes the MOT no problem, go home, no problem. Head out for my tyre appointment (a thing since C19),after 10 miles I see “Brake failure”. A bit of a test reveals plenty of brake but no ABS. Get tyres fitted, head home. Oh now I’ve got the warning triangle as well now. Six miles from home, 30 miles range showing fuel warning came on, two miles later I ran out of fuel with 28 miles range showing. Rude words were said, only a mile outside local town so I phone a local taxi company for a pickup, petrol station visit and return to start. Short story after 90 mins and 2 Taxi companies saying they can’t find a big blue BMW and a six foot bloke on a main A road given the name of the side road that I am standing next to, one claiming it join the A road. Even Bing maps can find it! I decide FTFAGOS I need to rescue myself, lock bike, pick up helmet, jacket, trousers, tank bag and head off. An hour later I’m back at the bike, melting, thinking next time take some trainers bike boots aren’t made for walking. Add petrol, start bike, swear at it doing the only just idling and won’t increase in revs thing for a bit again, ride home.
Tomorrow I shall be shining a bright light in the RT’s face and asking it some hard questions, well plugging in the GS911 and seeing what it says.
Tonight: Long soak in the bath.
I still enjoyed the bits of the ride between the bits that didn’t go well.
organist
Re: Today didn't pan out quite as expected.
Post by organist »
Yep - that sounds like a ride I had recently. Ran out of fuel - even though display said all was ok - 49 miles of fuel left. Abs light came on and then the ESA failed. Two trips back to Motorbikes 4 All, and a new feul strip, much work to braking system and a new rear shock (or reconditioned one) from Firefox, and at last the thing is working properly fro the first time since i got it in February. Fair play to MB4ALL, they msut've spent a fortune on the thing but they did it all under their s/h warranty without a grumble.
BMW R1200RT (2007 vintage)
Has liked: 136 times
Been liked: 204 times
Is that the dealer in Malvern?
organist
Post by organist »
Yes, it is Mike.
Rod wrote: Any ride that gets you home without tarmac surfing or sudden deceleration events is a good ride. However there are some days and rides that make you think “Should have stayed in bed”……
Made me smile, not your misfortune but the way you described it.
