Gas Cap Problems
wethead
Gas Cap Problems
Post by wethead »
I have seen a couple of mentions on 'not being able to open a gas cap'
Is there any aftermarketeers that sell a mechanical replacement gas cap for a 1250 RT?
Has liked: 330 times
Been liked: 159 times
Re: Gas Cap Problems
Lmfao yes BMW with non keyless option.
Been liked: 46 times
wethead wrote: I have seen a couple of mentions on 'not being able to open a gas cap'
It takes around 2 mins if the cap sticks to whip the screws out the front and release the cap. If it sticks, just get it replaced under warranty. Apparently the replacement caps do not stick
R2K
Gas Cap Problems
Post by R2K »
I am trying to understand what you mean by whip the screws out of the front?  Do you have to remove all the screws around the cap?  Or do you mean you only need to remove a couple in the front?  And by front do you mean closest to the rider or in front of the cap?
wethead wrote:Is there any aftermarketeers that sell a mechanical replacement gas cap for a 1250 RT?
http://pirateslair.net/SSRgascap.htm
In the UK, Motorworks sell used key type filler caps, https://www.motorworks.co.uk/vlive/Shop ... 0_36_GA_60
R2K wrote:I am trying to understand what you mean by whip the screws out of the front?
Found this on the R1200R Forum, https://www.r1200rforum.com/threads/key ... pen.33593/
"The two bolts at the top of the filler cap surround can be undone in an emergency and the top part lifted off - this will allow the cap to be opened".
R2K
Post by R2K »
David. wrote: Found this on the R1200R Forum, https://www.r1200rforum.com/threads/key ... pen.33593/
Excellent, exactly what I was looking for, answers all my questions.
Thank you very much sir, happy holidays
Just remember you have to put it all together at the same time, not like I did, took the screws out, opened the cap, then put the screws back in and then found the cap wouldn't shut, so had to undo the screws again and assemble together with the cap pushed down :)
If the cap won't shut, this video may show the problem, https://www.youtube.com/watch?v=pDSNufXU6sQ
wethead wrote:I have seen a couple of mentions on "not being able to open a gas cap".
You're not the only one, https://www.youtube.com/watch?v=x_W5VQdpvdM
David. wrote: If the cap won't shut, this video may show the problem, https://www.youtube.com/watch?v=pDSNufXU6sQ
When I dismantled mine, the sliding bit didn't have a pin, so it was either gone or it is a different mechanism now. Eitherway, once you you take the two front screws out, no matter what you do with that sliding bit, the cap won't shut with the front screws back in. I had to assemble the whole thing together, with the cap pushed down and then do the screws up. All fixed now and working ok :)
wethead
Post by wethead »
I buy one of these at the drop of a hat, but they ain't got none and don't wanna take order...sounds fishy
"FYI.. SSR is telling us that they completely out of stock and awaiting an all new shipment of caps. They tell me around Feb 1st, 2021! Will update as information comes in. We suggest you wait and check back with us in February before ordering."
Pirates' Lair also say, "In case you are curious... No.. the quality of SSR caps are NOT as good as the Oberon version hence the price difference, although they look identical."
Could always try an Oberon stockist, http://www.oberon-performance.co.uk/aca ... alers.html
wethead
Post by wethead »
David. wrote: "FYI.. SSR is telling us that they completely out of stock and awaiting an all new shipment of caps. They tell me around Feb 1st, 2021! Will update as information comes in. We suggest you wait and check back with us in February before ordering."
Wow, David, thanks, this is great news...do you happen to know if they have a gas-cap specifically for the 1250RT?
Then, I hope there isn't a code that comes up on the computer cause on yanks that electronic gas cap...whose idea was that anyways: and electronically operated gas cap...sounds as weird as a keyless motorcycle, don't it?
The anxiety of wondering when the fob batt is gonna go out and whether or not the gas cap is gonna open at the next top leaves something to be said for the 'stone-age'.  :bate: 8)
wethead wrote:Do you happen to know if they have a gas-cap specifically for the 1250RT?
"The GCBX2 cap (pics at top) fits the 2014+ BMW K1600GT / K1600GTL/ Bagger / Grand America, R1200GS 2013+, R1200GS Adventure 2014+, R1250GS, R1250 GS Adventure, S1000XR (all years), R1200RT LC 2014 +, R1250RT, R1200R / R1200RS 2015 + / For those bikes with the keyless ride option (electronic locking fuel cap)... it is just a simple swap. When you remove the electronic one, you'll obviously lose the keyless controls."
R2K wrote:I am trying to understand what you mean by whip the screws out of the front.
Found another useful video, R1250GS keyless stuck fuel cap : How to open it ? - YouTube
