If you have a "blow dryer" which do you have would you recommend it?
Has liked: 273 times
Been liked: 131 times
Re: If you have a "blow dryer" which do you have would you recommend it?
I would say that i find the hose helpfull.
Machine sits on seat can reach all but front of bike and no weight.
scunny12
Has liked: 42 times
Been liked: 53 times
Post by scunny12 »
Can I reverse the polarity on my Dyson V8 to blow clean air through the hepa filters???
Been liked: 484 times
The Sidekick Blaster can be used with a short extension hose & shoulder strap. Not sure that would be user friendly on a motorcycle. I think the idea is that it's handheld and waved around, like a hair dryer.
Perhaps a dryer on the ground with or without lockable castors and a decent length hose which doesn't just extend when the unit is switched on would be good, plus soft nozzles will reduce the risk of damage should they touch the bike.
Gravitis is a make which hasn't previously been mentioned.
They do a pet dryer for £98.55, https://www.gravitispetsupplies.co.uk/c ... ter-blower
or
a motorcycle dryer for £104.85, https://www.amazon.co.uk/Gravitis-3-2HP ... B07N7FTFW1
The power units are the same, although the pet dryer has a variable speed control which could be useful. The other differences are, the power cable and hose on the bike dryer are longer and it comes with castors.
Bruhl don't seem to have had a mention recently. This link to MSG Bike Gear, https://www.msgbikegear.co.uk/search?q=bruhl shows the old and new range of Bruhl dryers.
Teasdale Motorcycles at Thirsk are 25 miles away. They use & sell Bruhl dryers, https://www.teasdale-motorcycles.co.uk/ ... pe=product and would be able to demo the different models.
Bruhl are German, therefore, they have got to be the best!
Nick Evans
Been liked: 6 times
Post by Nick Evans »
[left]Don't know why you would want to do this, but it wont work for a number of reasons. Firstly, the HEPA filters are on the end of the air path, so the air going through them has already been filtered by the cyclones and motor pre-filter, then been through the motor. By reversing the flow the HEPA filters become the primary filters, they are very fine and likely to clog quickly. Second, by reversing the flow through the machine you will pick up dirt from inside the tank and cyclones and fire it out of the hose. Third, the motor depends on the airflow going through the machine for cooling, if you are using the HEPA filters as the primary filters and they have clogged up, the motor overheats.
All this talk of filtered air is a bit of a nonsense, we ride our motorcycles in unfiltered air. Most of these blaster things have some rudimentary filtration on them, mostly to protect the motor (as they use airflow for cooling) rather than to provide some sort of purified stream of unsullied air.
For the record, I have an Aeolus TD901T. On full blast water disappears as a mist and it dries all the way down to the skin. It even get loose undercoat out, so you cannot use it indoors without filling the room with fluff. It is a bit on the pricey side but it is not too noisy and has variable speed, which is very useful for training. When I use it on a motorcycle it is very effective, just be careful around switchgear and keyholes because you can blast water in through small gaps at 150mph if you hold the nozzle right up close to the switches, something which is not recommended in the same way that you would not direct a jet washer into the ignition switch at point blank range.
https://www.amazon.co.uk/TD-901T-CYCLONE-BLASTER-DRYER-UPDATED/dp/B005GK3YKC
scunny12
Has liked: 42 times
Post by scunny12 »
Seriously!  It was a joke.
Personally, I think all of this is a bit OCD and have never felt the need for any kind of air dryer. Keep my LC in a garage ,sprayed with ACF50 and that suffices after any washdown.
Been liked: 428 times
scunny12 wrote: Seriously!  It was a joke.
This is a great forum  :alas:  I now know about the filters on her Dyson :enjoying:
The local AYB guy who has ACF-50 treated my bike on a few occasions uses this dryer, seems a good enough recommendation.
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
Based on the above recommendation by AYB, have decided to go ahead and order a dryer.
The other thing of note is that in the last 7 days, the price has gone up by £5, now £76.12.
ovlovv70
Post by ovlovv70 »
Ordered and returned the dog type blower not quite powerful enough. Bought Bigboi which is a lot more expensive but is much better. Variable heat and variable blow.
ovlovv70 wrote:Ordered and returned the dog type blower not quite powerful enough.
Which dog type blower was it.
ovlovv70 wrote:Bought BigBoi which is a lot more expensive but is much better. Variable heat and variable blow.
Which BigBoi did you buy.
hammo
Been liked: 20 times
Post by hammo »
I,m thinking of buying a blow drier for my bike have not made up mind yet as some are a bit more expensive than others but give a longer warranty , have a bit more surfing , but Bruhl do look popular , the American versions give a two year warranty .
If the Amazon specification is to be believed, this dryer has an 8 years warranty.
This looks like the BigBoi range, https://www.theultimatefinish.co.uk/bigboi.aspx
Based on the replies to this thread, owners have the following makes/models.
Bruhl BD1240 x 1 (discontinued)
Air Force Blaster Sidekick x 2
Leaf Blower x 5 (make/model unknown)
Bruhl BD220 x 1 (discontinued)
Air Force Blaster x 2 (model unknown)
Pet Dryer x 5 (make/model unknown)
BigBoi x 1 (model unknown)
Of the "branded" ones, Air Force Blaster seem to be the most popular. After that, it's a toss up between a leaf blower and a pet dryer.
The Bruhl BD models have been superseded by a new MD range, https://www.msgbikegear.co.uk/search?q=bruhl
