Service Manuals?
Has liked: 123 times
Been liked: 98 times
Service Manuals?
As of yesterday, I am the proud owner of a 2017 R1200RT. Since I started out life as a motorcycle mechanic, I prefer to do my own maintenance. So today I hit Ebay for the standard maintenance CD's. I can't find any that cover my bike. Any suggestions on where to get a Service Manual for my bike?
TIA
Randy
Re: Service Manuals?
Randyjaco wrote:Any suggestions on where to get a Service Manual for my bike?
Haynes do a manual for the 2014 - 2016 R1200RT, R1200RT | Haynes Publishing it'll be the same as a 2017 model.
Has liked: 330 times
Been liked: 159 times
got haynes manual for MY17. does get a bit confusing between GS and RT though. Lots of good youtube vids availabe Box Flyer and Chris on the street to help with basics.
Boxflyer
Been liked: 31 times
Post by Boxflyer »
Deleted
Thanks. I live in Friendswood Texas by the way.  I just graduated from an F800ST and am enjoying the upgrade. I guess I will pick up a manual for the 2016 model. You confirmed my presumption that there hadn't been great changes from 2016 to 2017
Boxflyer
Post by Boxflyer »
Deleted
Boxflyer wrote: The biggest, and best change between the '16 and '17 is the improved end clearances on the transmission gear clusters and the addition of a "shudder damper" to the output shaft of the transmission.  Makes for the perception of smoother shifting.
Also a small change, is the relocation of the water pump weep hole from just an opening on the left engine case FWD of the LH cylinder, to a ridged pipe stub (just above the oil filter) with a rubber tube that carries any drips of coolant down to the underside of the bike near the tip of the shifter lever.
Another subtle change is the range of shim thickness used on the early years('13-"15) of WetHeads to the later years ('16-'21) of both WetHeads and ShiftHeads.  The first few years used a range of thickness down to 1.90mm and the '16 and newer seldom use a shim below 2.10mm.
One more thing to pay attention to is using Low Viscosity DOT4 Brake Fluid.  If you do a parts look-up for 83 13 2 445 461, (https://www.realoem.com/bmw/enUS/part?id=0A13-USA-09-2015-K52-BMW-R_1200_RT_0A03,_0A13_&mg=02&sg=05&diagId=02_0103&q=83132445461) you will see that DOT LV is called for in almost EVERY BMW bike made.  The owners manual only only specifies DOT4, and the performance of these ABS and DTC components require the rapid functionality afforded by the thinner viscosity fluids in the brake systems.
https://www.amazon.com/Pentosin-1224116-Brake-Fluid-Liter/dp/B00610SK2S
Trust me to have a late 2016 bike on a model change! Looks like I will have to probably figure some of these changes out
Boxflyer
Post by Boxflyer »
Deleted
I don't know about in the USA but over here its often possible to have a 17 bike registered in 16 and vice versa so somethings its a bugger to figure out which you have
