Battery Chargers
Which battery charger have you got?
BMW Motorrad - Plug In
4
12%
Optimate 4 Can Bus edition
14
41%
Oxford Oximiser 900 series
3
9%
Datatool (2004)
1
3%
Datatool Smart Charger
0
No votes
Accumate 6V/12V
0
No votes
Motopower MP00205A
0
No votes
Optimate III SP
1
3%
Optimate 3
4
12%
Oxford Oximiser 600 series
0
No votes
Deltran BT Plus 1.25A
2
6%
Deltran BT Junior 750mA
1
3%
BMW Motorrad - Ride Out
1
3%
Halfords 6V/12V
1
3%
Optimate DC-DC + Leisure Batt.
1
3%
OnBuy.com Foxsur
0
No votes
CTEK MXS 5.0
1
3%
LIDL Ultimate Speed
0
No votes
Total votes: 34
Re: Battery Chargers
Not surprisingly, the Optimate 4 Can Bus edition is proving most popular.
Currently available from BikespeedUK for £56.95, OptiMate 4 CAN BUS BMW Motorcycle Battery Charger (bikespeeduk.com)
If you would like to be thrifty and happy to bolt a pigtail lead to the battery (or use croc. clips),  then for £15 you can have this offering from Halfords,
Halfords 6V/12V Maintenance Charger | Halfords UK
Then again, if the charger must have BMW on it, Nippy Normans will happily take £139 off you for this,
BMW charger for R1200GS LC, R1250GS, K1600GT/GTL and all models after 2004 (nippynormans.com)
If you're happy just to use croc. clips, how about this for a tenner from OnBuy.com,
Car Battery Charger 12V Automobile Motorcycle Intelligent Pulse Repair on OnBuy
Levisp wrote: Anyone using a solar battery charger ?
I looked into solar power but you need to spend big for a decent result.The Optimate DC-DC is/was the most sensible answer for me.
Steve398 wrote:Just to be different - A CTEK MXS 5.0
There you go Steve, get your vote in.
One thing that the poll does show is that there are plenty of alternatives to an Optimate 4 Can Bus edition, charging via the onboard socket.
Some new R1250RT's won't accept a charge via the onboard socket, keep it simple and go directly to the battery.
BMW R1200RT / R1250RT forum - The BMW R1200RT/R1250RT forum
keith1200r
Post by keith1200r »
As far as I know the 2021 RT works fine from the fairing aux socket, not from the rear one. Mine charges fine through the front aux socket. No need for direct battery connections.
keith1200r wrote:As far as I know the 2021 RT works fine from the fairing aux socket, not from the rear one. Mine charges fine through the front aux socket.
Found this on BMWLT.
"I use an Optimate 4 through the aux socket on the fairing and it works fine. The one near the pillion seat doesn't seem to work for charging."
Oldnickers wrote:Initially I thought it was because I was using the rear charging port but the fairing one yielded a similar problem.
This problem was with a BMW charger!
keith1200r
David. wrote: Out of interest, have you tried using the rear socket and which battery charger are you using, BMW or Optimate 4 Can Bus.
Yes, I have tried the rear socket - doesn't work. Optimate 4 charger. Front one is fine. I have seen other comments reporting the same issue.
PeteM
Post by PeteM »
keith1200r wrote: As far as I know the 2021 RT works fine from the fairing aux socket, not from the rear one. Mine charges fine through the front aux socket. No need for direct battery connections.
Mine charges fine through rear socket, BMW charger
Well, there you go then, confirmation that the onboard socket charging problem is bike specific not down to which charger is being used, BMW or Optimate 4 Can Bus.
keith1200r
Is it the 2021 model?
PeteM
Post by PeteM »
keith1200r wrote: Is it the 2021 model?
Well according to my profile over there <<< what do you think?
Can't beat a good film, https://youtu.be/wbzKvGyr6Yo
LIDL middle aisle have this Ultimate Speed battery charger for £12.99, https://youtu.be/IYv4S19QOJQ
