rear brake pads 1200 2007
Has liked: 1410 times
Been liked: 404 times
Just replaced my rear brake pads with EBC HH pad. I know BMW recommends standard sintered pads on the rear but i like the feedback from the HH pads.
One question i have is why is one pad thicker than the other?. I've contacted EBC and they inform me i have the correct pads but the person couldn't explain why one is thinner than the other. Do you know why?
yorkie
Been liked: 13 times
Re: rear brake pads 1200 2007
Post by yorkie »
Doctor T wrote: One question i have is why is one pad thicker than the other?. I've contacted EBC and they inform me i have the correct pads but the person couldn't explain why one is thinner than the other. Do you know why?
I've no idea why, but if that is the case surely they have to be handed. Seems strange to me :-X
Been liked: 474 times
Doctor T wrote:One question I have is why is one pad thicker than the other.
From what I have read elsewhere https://www.ninetowners.com/threads/uneven-rear-brake-pad-thickness.141033/
and having viewed this video, Disk brake / Floating caliper brake - How it works! (Animation) - Bing video
the outer pad (nearest the piston) is thicker than the inner because the rear brake has a floating caliper.
In the video, as the brake is applied/released, the outer (thicker) pad makes & remains in contact with the disc fractionally earlier & longer than the inner pad.
Seems like a reasonable theory.
yorkie wrote:If that is the case surely they have to be handed.
They are, BMW R1200RT Rear Brake Pad Service - YouTube
yorkie
Post by yorkie »
Thank you David, live and learn eh  ^-^
It's strange ive never seen this on other bikes ive owned over the years. Are there any other makes of bikes that have the same set up?
Doctor T wrote:Are there any other makes of bikes that have the same set up?
Triumph, '98 Sprint Sport - two rear brake pads are different thickness | Triumph Rat Motorcycle Forums
