Just ordered a Zumo XT, but the Adapters are out of stock
potatan
Been liked: 5 times
Post by potatan »
After reading a number of comments I've ordered a Zumo XT, on the understanding that I would get a mount from the Italian place - this one: https://www.adapter3dmotorrad.com/en/product/e-nav-xt-rt/ - to take care of power needs etc.
The Zumo is now on its way to me but unfortunately the 3d Mounts are out of stock.
What would you do as an alternative arrangement? I'm due to be travelling in around a month or so!
Thanks
Been liked: 46 times
Re: Just ordered a Zumo XT, but the Adapters are out of stock
I bought 4x 40mm 4mm bolts, 4 x 18mm x 4mm spacers and a BMW accessory cable from Motorworks which plugs into the same socket the Nav powers from. I then mounted the XT cradle in front of the Nav cradle. Just to finish it off I also drilled 4 holes in the Nav blanking plate so the new mount sits in front of that, so it looks original. Not a hard job and looks good. You will need a tool to be able to release the Nav as you can't get to the button when its mounted, but a cheap trim removal tool works fine and this is a bit of added security :)
Levisp
Post by Levisp »
Here are some photos of how I fitted a TomTom mount for a Rider 550. Now removed and replaced by a Quadlock mount for my phone. Used sheet plastic to make the face plate and spacers. Last photo shows BMW plug that the Nippy's socket fits for switchable power.
Fourbears
Been liked: 6 times
Post by Fourbears »
Just keep checking as I had that problem but a couple of days later they were available again.
Has liked: 609 times
Been liked: 585 times
Whats your location?
Fourbears
Been liked: 6 times
Post by Fourbears »
Norwich
Fourbears wrote: Norwich
That question was for Potatan unless you're answering for him?
potatan
Been liked: 5 times
Post by potatan »
I'm in Gloucestershire
jjwill
Been liked: 5 times
Post by jjwill »
potatan wrote: I'm in Gloucestershire
Shame you're so far! if you had being really stuck I could have helped you out with a temp solution and lent you a mount
potatan
Been liked: 5 times
Post by potatan »
Thanks so much. To be honest I'd have made a trip to meet you just for a good blast, but as someone spotted they are now back in stock and I have one on the way.
Thanks again
Sent from my GM1903 using Tapatalk
potatan
Been liked: 5 times
Post by potatan »
jjwill wrote: On sale again on website https://www.adapter3dmotorrad.com/en/product/e-nav-xt-rt/
Brill thanks, just snagged one
Levisp
Post by Levisp »
Glad you have a solution. When you get yours do post a short review with some pics.
Levisp wrote: Glad you have a solution. When you get yours do post a short review with some pics.
https://www.zumouserforums.co.uk/viewtopic.php?t=1318
Levisp
Post by Levisp »
Thanks Sakm. Not personally interested in the Garmin XT myself but always interested in seeing other peoples solutions.
