Hello - forgive me if this is a repeat - I tried the search function but came up empty.
I just bought a set of Wunderlich vario rider adjustable footpegs. The installation instructions are complete crap. The problem lies with the springs on the brackets. When I try to reassemble the pegs, the stock spring won't engage the spot on the bike where it did on the stock setup - it seems to be too short by just a few mm. I watched the video, but it was not RT specific and simply tells you to "reinstall the springs"
Anyone else already solve this problem?
Wunderlich Vario footpeg kit - poor installation instructions
- Been liked: 427 times
Re: Wunderlich Vario footpeg kit - poor installation instructions
The springs are a pain in the arris,this is the video i followed(supplied by Steve)
[size=2px]https://youtu.be/vBvUB7VIy0A[/size]
- Steve398
- Has liked: 502 times
- Been liked: 435 times
burridge01 wrote: The springs are a pain in the arris,this is the video I followed(supplied by Steve)
I think these are different mate, being the vario adjustables... and yes, the springs were a complete PITA!
Yes - thanks, but I found this video already - the vario is a different setup.
bmwone wrote: Hello - forgive me if this is a repeat - I tried the search function but came up empty.
I solved the problem by inserting the original pivot pin in the assembly, and left the pivot bushing out of the middle of the bottom of the spring initially. I then used a pair of channel locks to squeeze the spring towards the centerline, and when it was there, slipped the bushing into place and put on the circlip. Worked perfectly.
Time will tell if the complexity and expense of the vario system is worth the price.
