Cost to fit brake pads
Has liked: 136 times
Been liked: 204 times
Waiting for a call back from main dealer regarding a price to fit rear brake pads. What has been other people experience?
I'm guessing it'll be around 150-200 quid.
Re: Cost to fit brake pads
You could do it yourself, not a big job... OEM pads a bit pricey but you could use EBC or Brembo?
MikeS wrote: Tue Oct 04, 2022 12:50 pm I'm guessing it'll be around 150-200 quid.
:shock: :shock:
If it was that price,would you pay it.
David and Sally
Has liked: 13 times
Been liked: 16 times
Post by David and Sally »
Do it yourself if you are capable.
burridge01 wrote: Tue Oct 04, 2022 1:25 pm
:shock: :shock:
No I'd go with an independent, the place that does my tyres. However, I'm hoping to be surprised by BMW and it costs nothing to ask. If they charged a little bit more than the independent then I'd go to BMW.
Can I fit them myself? I've all the mechanical aptitude of a chimpanzee and prefer to leave it to somebody that knows what they're doing.
MikeS wrote: Tue Oct 04, 2022 2:18 pm
:shock: :shock:
I’m frequently surprised by BMW prices :shock: :lol:
Been liked: 46 times
Just had a set of pads fitted to one of our fleet bikes. Pads and spring plate (which they quite often change at the same time) £62 (with 10% discount). Fitting was free. But fitting rear pads is very easy and a 15min job if you take your time.
Been liked: 258 times
I replaced all mine for around £68
Turns out 200 quid estimate was very pessimistic.
No call back from North Oxford so rang Cotswold Motorrad.
70 quid fitted including new caliper bolts.
Has liked: 330 times
Been liked: 159 times
Always prefer to do own brakes as most mecahnics wont clean calipers. cheaper and I know done right.
If you know what you're doing, you can have the front and rear fitted within 30 minutes. It's one of the easy jobs to do
vulcanbike
Been liked: 4 times
Canada
Post by vulcanbike »
Yes its a simple task, but in the video one important step was missed. You know that these rear brakes are called floating calipers. What this means is the caliper is attached to a bracket. The bracket is attached to the rear axle. So now when you apply the brakes the two pistons push the outboard pad against the rotor. When this happens the caliper then slides on the pins to engage the inboard pad against the rotor. If those pins are not serviced to make sure they slide easily, they will eventually seize and let me tell you, you will be in for a whole lot of hurt. BMW has made sure that what should be a replaceable part is not, and if you cannot unseize those pins, its a whole new caliper. I can tell you this from experience. After much penetrating oil and heat applications I got my apart. Took two days. By then the rubber boots where shot. BMW wanted $65 for those two tiny rubber boots. Managed to find a Dorman part that was identical for $11. So make sure those pins are lubed and slide easy.
Marvin2Shoes
Has liked: 76 times
Been liked: 17 times
Australia
Post by Marvin2Shoes »
Excellent detective work!
Are these rubber boots identical across models or peculiar to wetheads only for example?
Regardless of model compatibility, many could benefit from your expertise...
Do you have:
a) The Dorman part number, or
b) A reference to the Dorman model of which rubber boot was a part?
Many thanks for your post.
2011 R1200RT Highly Modified
vulcanbike
Been liked: 4 times
Canada
Whoops I was wrong, its not Dorman, but a Carlson brake part # 16165. It's a kit which by the way comes with 4 rubber boots.
