Starting Issue
Has liked: 136 times
Been liked: 204 times
Starting Issue
My R1250RT has developed a starting issue, going to book it in to be looked at but before I do would welcome any collective wisdom.
Turning on with the keyless button then starter button starting as normal, cold or hot.
Turn the bike off on the kill switch and attempt to start again it gives one turn of the starter motor and then nothing. Dash switches off and resets itself after the keyless button is used to turn the ignition back on.
Suspect its simply a problem with the starter/ kill button but any other ideas ?
Re: Starting Issue
Is this the first time you've turned the bike off with the Emergency off Switch (Kill Switch).
Re: Starting Issue
No , done it a few times before without any problems. Usually if I'm at a standstill and trying to hear what someone is saying to me over the engine noise.
Re: Starting Issue
A mate is having similar issues with his GS
I am suspecting its the battery on his! he is going back to the dealer
Re: Starting Issue
sakm wrote: Thu Jan 26, 2023 9:04 pm A mate is having similar issues with his GS
He has figured out his problem!
It was a loose battery connection!
Maybe check yours before a trip to the dealer
Re: Starting Issue
sakm wrote: Fri Jan 27, 2023 8:36 am He has figured out his problem!
Will do.
Cheers
