Rear bevel oil
Rear bevel oil
Just serviced my 07. All fluids except the brake and clutch as i changed them last March.
Old age must be setting in because i can't remember how much oil the rear drive bevel takes. I think it's something like 80Ml and the same oil as the gearbox. The oil looks quite clean seeing ive clocked up 13000 miles since last March, just needs replenishing now.
Re: Rear bevel oil
If its the same as the wet head it's 180ml
I will check soon if no one beats me to it
Re: Rear bevel oil
Cheers, Stu. I thought there was a 80 in there somewhere
Re: Rear bevel oil
The Haynes manual for a Hexhead doesn't give a FD oil capacity because at the time, it was changed at 600 miles then in for life.
For a Camhead, it's 180 ml, it'll likely be the same for a Hexhead.
Re: Rear bevel oil
The original spec. gearbox oil for a Hexhead was SAE 90 and the FD was the fancy 75W-90.
Re: Rear bevel oil
Cheers David. So gearbox is the same as rear drive as i thought
Re: Rear bevel oil
here you go :thumb:
180ml :)
2007 rear drive.pdf
(479.89 KiB) Downloaded 456 times
Re: Rear bevel oil
What is that from?, it's not Haynes
Re: Rear bevel oil
This 2007 Hexhead doesn't have separate drain & filler plugs, (Camheads do).
Re: Rear bevel oil
Mine has a drain and fill plugs. As he said mine must have been replaced at some time.I will look through the service history as am sure it has something about a warranty claim for bevel and shaft
Re: Rear bevel oil
My 2007 Hexhead was as per the video, FD oil changed at 600 miles then never again.
Been liked: 258 times
Re: Rear bevel oil
Service data 0368 - R 1200 RT
2007.pdf
(1.21 MiB) Downloaded 671 times
Re: Rear bevel oil
Thanks Glenn
Re: Rear bevel oil
Doctor T wrote: Fri Mar 10, 2023 4:34 pm What is that from?, it's not Haynes
Its the BMW RSD manual which covers pretty much all models
Its apparently what BMW use
Re: Rear bevel oil
Where can i get it from
All back together, renewed oil, splines grease
Thanks for the help chaps :thumb:
