Hill Start Control
Re: Hill Start Control
The HSC is much improved on the 1250s pulling away is easy. On the 1200s I used to use the pull the brake leaver as I got to the bite point to release. Seemed to be easy to stall otherwise. Whether there has been any software updates on the 1200s to make the HSC as effective as on the 1250s, I don't know, as I don't have a 1200 anymore
- Been liked: 471 times
Is it correct that the HSC on a 1200 only had a manual mode. Whereas, the 1250 has both HSC and Hill Start Control "Pro", one is manual and the other an auto mode.
Identifying the bike model and year would possibly help to confirm the above.
- Been liked: 4 times
Yesterday's warm and sunny late January weather was fantastic for a 220 mile ride across the beautiful countryside of East Tennessee and the Cumberland Plateau. Thanks to all the tips on activating Hill Start Control I finally had success in turning it on and off. Prior to yesterday, I had simply not been squeezing the front brake lever hard enough to activate it. Now to get smoother on the take offs while HSC is active.
Thanks to all for the tips and comments.
- Stu
- Has liked: 609 times
- Been liked: 585 times
I have been out on mine today no warmth or sun though!
I purposefully used the hill hold and set off with it on to see if I can fathom it out
It turns out that if you get the bite point then just add a little bit more throttle and a little bit more clutch till you feel it trying then hold everything as is ie no more throttle or clutch it will then release after a few seconds giving a nice smooth set off
- Steve398
- Has liked: 460 times
- Been liked: 381 times
I use mine frequently, particularly at traffic lights where there’s any kind of gradient, but always release it by reapplying the front brake rather than try and overrun the resistance.
Against my initial reservations I find it very useful.
- Bike Model and Year: 2015 R1200rt
- Been liked: 14 times
I recently read, like sakm states, if you operate the hill start assist system, then slip the clutch to hold your position , the hill start assist will release
and you can power off smoothly .
Having succeeded on a few medium inclines, albeit with no one behind or in front of me, I am going to persevere with it and try on some serious hills.
Sakm, did you find the reason for your low rear brake pressure .
bob
bob
- Stu
No not yet! Still not had chance to get it to a dealer! I keep riding it instead
- Jggpossum
- Has liked: 3 times
- Been liked: 20 times
The main "trick" I have found is that you have to pull the brake lever quite hard. If the H symbol hasn't come on then squeeze a little harder until it does. Very predictable and reliable. On take off I have learnt to give that little bit extra throttle as the clutch starts to bite.
Takes a bit of getting used to, but the skill involved is no greater than using the rear brake and learning to release gradually. But the benefit of allowing both feet to be on the ground in perfect balance is worth it.
