Battery Charging.
Our Gee
- Been liked: 34 times
Battery Charging.
The Haynes Manual (R1200 D.O.H.C. Twins 2010-2012) specifically states "Do not connect a battery charger to the battery terminals while the battery is on the Bike". As I have always carried out this very procedure (Three R1200RTs) without any known problems I am wondering just what negative results "could" have occurred. I carry out charging using an Optimate Charger coupled direct to the Battery Terminals via an additional Aux. Socket.
- Been liked: 506 times
Re: Battery Charging.
I think the danger is that, some de-sulphating battery chargers can deliver up to ~18 volts which may damage the voltage sensitive electronics on the motorcycle.
The alternator onboard charging system is voltage regulated to a max. of ~14.5 volts.
