05 BMW RT 1200 ESA Not Functioning
paulmarler
Bike Model and Year: 2005 1200rt
Post by paulmarler »
Good afternoon
my ESA seems to be not functioning i have toggled between all settings...sport, comfort, and normal but it seems the bike rear shock doesn't move at all. there are no error codes ( least i think on screen) ive read that this is common on ESA1 bikes like mine 05-09 rt 1200's
i have also read dealers can update software that may fix this issue but I'm not sure this will be a fix,
is there an alternative shock that will work to correct this issue? has anyone here experienced this with their RT? and how did you fix this issue??
some items ive read state water gets into the bottom plug and rusts it out, some the motor on ESA 1 fails because the nitrogen assist leaks out and the electric motor is not strong enough to push the rod that adjusts teh shock.
thank you for any advice given im at a loss
Re: 05 BMW RT 1200 ESA Not Functioning
Sport, comfort & normal are damping settings, I wouldn't expect to see the rear of the bike move.
However, when switching the preload between the three load settings, the rear end will raise up & lower down.
paulmarler
thank you david
im sorry i was not clear, the pre load is not working. i press ESA button and hold it but it doesn't do anything. at moment the bike is stuck in the raised position
paulmarler wrote: Mon Jun 03, 2024 2:28 pmI press ESA button and hold it but it doesn't do anything.
Are you doing it whilst the engine is running.
paulmarler
yes tried while running, and with just key on. does kickstand have to be up??
paulmarler wrote: Tue Jun 04, 2024 3:37 pm
No.
paulmarler wrote: Tue Jun 04, 2024 3:37 pmDoes kickstand have to be up.
No.
paulmarler
well seems its borked made appointment at dealer to look at it... im sure its broken and BMW does not have this under warranty, and doenst have a replacement part. https://www.beemershop.com/ seems to be the way to go
