Front left storage compartment. 2020 R1250RT
BBT6000
Bike Model and Year: RT1250
Has liked: 3 times
Post by BBT6000 »
I’m unable to open the front left storage compartment. Should the key slot be in line with the wheels, or at 90 degrees to them?
Mine could be seized through lack of use but I don’t want to force and sprain anything.
Re: Front left storage compartment. 2020 R1250RT
90 degrees :thumb:
If you have central locking make sure that is unlocked too
Shuswaper
Has liked: 3 times
Been liked: 11 times
Canada
Post by Shuswaper »
A little WD40 and push, assuming its the same design as the 21's and up.
Roper424
Bike Model and Year: 2015 RT 1200
Has liked: 17 times
Been liked: 4 times
Post by Roper424 »
I had a similar issue a couple of weeks ago. I think the rubber seal can fold the wrong way and gum up the working on the lock. I ended up having to pry it open once I’d seen which way the key needed to be (can’t recall that bit off the top of my head). But you may need a wide, thin tool of some form to gently lift it open.
Remember, ride to arrive alive!
James.
:cheers:
Robbrue
Post by Robbrue »
My R1250RT is still covered under warranty. The front left storage fills with water when I wash it. The dealer told me that this compartment is not supposed to be water tight and it is not a covered repair. He offered to drill a hole in the bottom of the compartment to allow the water to drain out? Does anybody else's compartment leak water? Is it really normal to leak?
Gareth1962
Been liked: 9 times
Post by Gareth1962 »
Have never specifically checked mine, either after a wet ride or washing, but seeing there is a small paper note pad and small box of matches in it - I have never noticed them wet/damp!!! If it wasn't designed to be waterproof, why put in the rubber seal begs the question?
2021 R1250RT LE Blue
Has liked: 136 times
Been liked: 204 times
Robbrue wrote: Wed Sep 11, 2024 1:02 am My R1250RT is still covered under warranty. The front left storage fills with water when I wash it. The dealer told me that this compartment is not supposed to be water tight and it is not a covered repair. He offered to drill a hole in the bottom of the compartment to allow the water to drain out? Does anybody else's compartment leak water? Is it really normal to leak?
Mine has never let any water in.
Mine neither-16 plate.
Mine has!
Not a great deal but only when I wash it
Robbrue
Post by Robbrue »
I felt like it was kind of a bogus excuse. I will press my dealer on the issue. Thank you for your replies.
MattyP
Post by MattyP »
3 years on and mine is as dry as a bone. Don't accept the dealer version - ludicrous! As Gareth1962 said.....why the rubber seal if it's not meant to be waterproof?
Robbrue
Post by Robbrue »
FYI I pressed the service manager, he replaced the seal, and it's bone dry now. Thanks all.
